Old 11-15-2010, 03:42 PM
Dalton G is on a distinguished road
Problem When i try to bring up T2!
Hi, iam new here and was wondering if i could get some help. I changed the timming belt on our Excel PMC-5T18. Every thing works ok, but now when i got to bring up tool 2, (T2M6: ) I get an error message. OPERATOR MESSAGE NO. 2050, T code error due to:
1)T code not applicable, or
2)Duplication of tool number in tool Data Management. Address D100 to D124, or
3)T code not available for Big Tool set.
Is there any way some one could help me? Thank you.
Dalton Greer
JACO Machine Works
Old 11-15-2010, 07:55 PM
SORCHEROR is on a distinguished road
when you say changed timing belt,you mean the spindle belt?if so you need to orient the encoder right and im not sure how to do that,i watched a tech do it for my haas and still dont know how,check your manual
Old 11-16-2010, 01:01 AM
Swemill is on a distinguished road
I suppose that Dalton means that this only happens on T2, and not on any other tool and isn't that strange if that should be the encoder!?
Anyhow, to adjust the spindle orientation in my Fanuc MXP-100i at work it's the value in par.4077, but you need to check wich par for your control in your manual!
If it has with "Big Tool Set" to do, you do that settings in DGN, but again you must check you're manual.
Kitamura Mycenter 1 -83 with Fanuc 3M-C and Mycenter 1B -85 with 10M control.
Yes, they are old..... but i still like them!
Old 11-17-2010, 10:43 AM
Thank you, but where would the DGN settings be? Iam looking in my Fanuc Parameters manual and came not find anything.
Bring table to center bowmaster Haas Mills 10 07-25-2010 10:17 PM
Moving to Oz, just how much of the shop to bring.... janders57 Australia, New Zealand Club house 19 07-06-2009 04:30 AM
Backlash...bring the flames. JeepJake Industrial Hobbies (Support forum) 27 02-07-2009 11:06 AM
Build Thread- bring you fortune lianglish CNC Swiss Screw Machines 0 08-22-2008 02:21 AM
How bring together Fadal 32 MP and PC puberter Fadal 4 01-22-2005 12:59 PM
