Old 11-10-2010, 11:24 AM
blakemachine is on a distinguished road
Fanuc 10tf, Axis Torque Alarm, mem Z axis Alarm, already changed Z drive and motor?
Figured I would start a new thread, as the old one was somewhat off track.
This is what I find in the ladder, and by on and off, I mean on is lighted up as white, and off is just regular green.
R102.0 ALARM ON
R283.0 HYD PRESS NORMAL off
R283.1 HYD PRESS ABNORM off
R283.2 AIR PRESS NORM off
R283.3 AIR PRESS ABNORM off
R283.6 LACK OF LUBE off
R400.0 MOTORS ALARM off
R400.1 BREAKERS TRIPPED off
R400.2 SP MOTOR ALM off
R400.3 AXIS TORQUE ALM ON
R400.4 PRESSURE ALM off
R400.5 LACK OF LUBE off
R400.6 Q-SETTER ALM off
R400.7 TOOLS USED UP off
R401.0 MEM X AXIS TORQUE ALM Off
R401.1 MEM Z AXIS ALM ON
R401.2 CENTRE ALM off
What shall I do now, I have changed the Z axis drive and the drive motor. What should I look for now? I am also getting a Z axis slow limit switch error. I have checked the switch, with a continuity tester, and checked the terminals at the switch, and that all checks out, but I cannot clear that alarm either. Anyone know where to check now?
Here are some photos of the ladder
Here is also a vid of the ladder, notice how they go from on and off really fast?
YouTube - MVI_0457.AVI
Old 11-11-2010, 12:42 PM
tmbruno28 is on a distinguished road
just look on your ladder, you might have somewhere on the line of the coil of R401.1 , a keep relay and you need to set it to zero manualy .
It is a safety system frequently used on wasino lathe and lot of others MTB .
Need Help!- Chiron X Axis Torque Alarm 409 Laig General Metal Working Machines 2 01-27-2012 08:54 AM
Alarm 409-servo alarm- z axis torque alm jessebpm Hyundai Kia machine 3 06-14-2010 07:45 PM
Need Help!- Fanuc 6 M Alarm 401 and 420 Y Axis CBMach Fanuc 6 12-21-2009 01:50 PM
X axis torque alarm on Takisawa Lathe lkenney General Metalwork Discussion 3 08-27-2009 02:14 PM
Fanuc 10tf Alarm L. Sakthivel Fanuc 1 05-29-2007 10:49 PM
