Old 11-02-2010, 04:53 AM
ahmed4040 is on a distinguished road
DGN parameters problem in Fanuc Otc
Dear All,
i Have i lathe machine with controller Fanuc Otc, i have delete all the parameters according to a problem happend to me.
then i have restored all parameters except DGN parameters because i restore it because a problem in RS232 port.
i have entered all parameters manually, and now i can not find the DGN parameters screen to enter it by hand.
so can anyone help me in details how to input or restore the DGN parameters and where to find it.
Thank you
Old 11-02-2010, 08:00 PM
stevo1 is on a distinguished road
There should be a DGN/PRM key on the monitor or as a softkey. If not then you may want to double check your 900 parameters to make sure that you entered the proper values.
Stevo
Old 11-03-2010, 03:13 AM
Thanks Stevo for your help,
i found the DGN parameter screen, but i can't edit it by hand !!
i'm in MDI mode and PWE is 1 and i can't edit these parameters.
when i try to change the parameter, i type the new value and press input but nothing change and i did not receive any error message to know what is the wrong thing !!
Old 11-03-2010, 12:13 PM
tmbruno28 is on a distinguished road
your edit programm
key must be also on !!!!
Old 11-03-2010, 01:47 PM
i entered all other parameters !!!
all parameters have been entered except DGN option file.
note : Program protect is ON
all i want that : to enter this DGN file manually by (hand)
Old 11-03-2010, 03:47 PM
can you tell me witch number of diagnose you try to enter please , and what is the machine ? Please check diag 122#3 .
Old 11-04-2010, 01:44 AM
from 300 to 450
the machine is Yida cnc lathe - Fanuc 0tc
Old 11-04-2010, 09:52 PM
NICK1945 is on a distinguished road
fanuc 0TC diagnostics
Ahmed there is a softkey under the CRT screen
the 300 to 450 diagnostics are very important for the machine operation they are put there by the machine builder.
They control such things as Turret, Chuck etc.
Old 11-05-2010, 03:39 AM
no one tell me till now, how to input these parameters by hand ?? that is all what i need
Old 11-05-2010, 07:35 AM
Ahmad…..sorry, I lost track of this thread. Looking at some old notes it appears that you need to set parameter 393.7 in order to edit the PMC data.
Stevo
  #11   Ban this user!
Old 11-06-2010, 04:42 AM
finally i got it, it's supposed to press "EOB" while inputting the parameters.
thanks all
  #12   Ban this user!
Old 11-08-2010, 06:54 AM
Interesting. I don’t see that in any of my notes. I will make a note of it. I am glad you got it figured out.
Stevo
Problem- 5T Cadillac parameters, or bigger problem? parkerbender 5T/5M 29 04-24-2010 12:59 PM
Need Help!- Fanuc 3t parameters lloydy304 Fanuc 1 10-31-2008 07:38 AM
Need Help!- Parameters for fanuc 0T Mrmendiola Fanuc 3 10-27-2008 11:03 AM
Fanuc 18-T DNC Parameters JerryH Fanuc 4 12-13-2007 07:15 PM
Parameters problem on SCM Routron claucampan Machine Problems, Solutions , Wireless DNC, serial port 0 08-10-2006 02:25 AM
