Old 11-01-2010, 06:17 PM
wsd wsd is offline
wsd is on a distinguished road
Fanuc11M Buffer Overflow
Hello,
We just got three older machines. A mazak, matsuura and a mori seiki. All have Fanuc 11m controllers. The mazak is now connected on the network and is able to send programs into the control with no problems. 9600 baud setting. So for the mori and matsuura I made the same cable for both identical to the one I made for the mazak.
Both the matsuura and mori produce Buffer overflow errors.
Reducing the baud produces framing errors. Also tried fifo off or unchecked.
Any ideas on the Pinout for 25pins(Fanuc controller) to 9 pins_female(PC)? Fanuc 11M rs232 manual? Suggestions?
Thanks, Joe
Old 11-01-2010, 06:51 PM
Al_The_Man's Avatar
Thanks, Joe
Send me a PM with an email add for the manual.
Old 11-01-2010, 08:53 PM
angelw is on a distinguished road
Hello,
Thanks, Joe
Joe the following pin out works fine for Xon Xoff (Software handshaking). Some diagrams show the PC end jumped as well, but this is unnecessary.
Your transfer software needs to be set for Xon Xoff handshaking and the baud rate has to match what is set on the control. Changing to a slower baud rate at one end only, as the framing error you received would indicate you have done, will not resolve the buffer overflow. 9600 baud is not unreasonable for an 11 series control, so the parameter settings for the two controls not playing the game would be my first point of inspection. With the cable described, make sure that the transfer software handshake setting is set to Xon Xoff handshaking, not hardware or RTS/CTS handshaking, and definitely not set to None.
If you continue to have problems with buffer overflow with the below cable and the correct setting at the control and PC, check to see if your transfer software has an option for a short delay at the end of each block. If so, set a small delay, say10ms and see how that goes. Implementing a delay has a different effect than just using a slower baud rate; you will not see much change in transfer speed even with a 50ms delay. I won't explain why here now, but it does have a marked effect on buffer over run if everything else is set correctly.
Regards,
Bill
Machine End------------PC End
25 Pin-------------------9 Pin
2------------------------2
3------------------------3
7------------------------5
4-|
| bridged
5-|
6 -|
8 -| bridged
20-|
Old 11-02-2010, 08:15 PM
stevo1 is on a distinguished road
Buffer overflow is pretty common on the 10,11 series control. You need to go into the control panel on your PC and select controlpanel>system>devicemanager>ports>select the port you are using>portsettings>advanced. Turn down the FIFO buffers on the transmit.
Stevo
Need Help!- buffer overflow wildhorsemfg Fanuc 4 09-19-2010 03:45 AM
FANUC 15M SR844 BUFFER OVERFLOW (3) andre324 General CNC (Mill and Lathe) Control Software (NC) 2 03-04-2010 04:06 PM
Need Help!- Buffer overflow OKUMAN Okuma 3 02-08-2010 02:53 AM
Fanuc 10M Buffer Overflow nastek Fanuc 5 04-30-2009 07:15 AM
SR 834 Alarm Buffer Overflow 2 When Dripfeed TWyatt9 Mori Mills 3 03-26-2008 10:47 PM
