Old 10-25-2010, 12:39 AM
M.RISHIKESH is on a distinguished road
Gleason(Phoenix)Gear Cutting Machine Model 500HC with GE Fanuc Series 150M
Dear All,
We have got frequent problem of cutter breakage in this machine since last 4 months
Last time when cutter broke, before that machine was quite alright for 16 hours and then suddenly cutter broke, every time cutter breaks we get error SV001 : Y axis excess current in Servo, No alarms LEDs on Fanuc Servo drives
Cutter spindle is mounted on X-Y plane & Workpiece spindle on sliding base(Z) axis.
we dont doubt any synchronisation failure between 2 spindles because machine is ok even may be for 3 shifts (ie 24 hours).
Yesterday we found chips got clogged in front of the sliding base(Z), operator feedback suggests that every time cutter broke, chips found trapped as flushing coolant not working
Kindly advice that is it possible that trapped chips obstruct movement of sliding base when sliding base moving in cutting feed (which is low) during interpolation & due to that uneven load comes on vertical axis(Y) and cutter breaks and finally error SV001
Both Servo Drives (For X,Y & Z,B) recieved from Fanuc after thorough repair at their repair center
Linear scale active in X & Y, Heidenhain scale in Z not working since a very long time (that means much before than the cutter breakage started in this machine)
All machine parameters quite intact and checked as per Hard copy recieved with the machine around 15 years back
No such abnormality noticed in machine
Kindly advice for the above
Best Regards,
M. Rishikesh
Need Help!- Cutting tool Phoenix-Paxton model WL36 CNC lathe garfieldsimons Want To Buy...Need help! 0 09-07-2010 08:29 AM
Need Help!- Fanuc Series O-M model T ddorin Fanuc 8 04-28-2010 02:14 AM
Need Help!- Phoenix Gleason 500HC CNC Hypoid cutting Machine No. 899401 with GE Fanuc Series 150M M.RISHIKESH Fanuc 2 10-16-2009 07:22 AM
Need Help!- GE FANUC SERIES 150M M.RISHIKESH Fanuc 2 10-06-2009 07:56 AM
Gear cutting machine? DennisCNC General Metal Working Machines 1 09-10-2008 11:26 PM
