| Hi ! Im having a CHATTER problem when cutting metric thread (M24x2) on my Cnc lathe KIA TURN with fanuc controls. In fact im machining a steel but its happens that my thread are comming out with terrible chatter. Here is the overview of the program; N4(Thread M26x2) G40G0T0303; G97S400M3; G0X25.Z10.M08; G01Z6.161; G71P000030 Q250 R30; G76X21.546 Z-20. P1227 Q280 R0 F2.0 |
| You did mean to put G76 (not G71) in the first block of the cycle, right? G71P000030 Q250 R30 I don't work in metric, but it looks to me like the Q (min depth of cut) in the first block is 0.25mm which is 0.0098. These are pretty heavy cuts at the bottom of the thread. Also, your tool angle is 30, which I believe results in a 15 degree infeed, which may be a little steep. Have you tried 60 or 55 degrees? Lastly, you're not taking any "spring passes". Don't know if that would help or not. |
| Inch Mode (nnnn.nnnn): R0.03 = 0.0300 R30 = 0.0030 MM Mode (nnnnn.nnn): R0.03 = 0.030 R30 = 0.030 |
Yes, I know that trailing zeroes can be omitted. I included them in my example for clarity. |
| Chatter? | vectorsc | Mazak, Mitsubishi, Mazatrol | 5 | 12-07-2009 08:39 AM |
| Need Help!- Chatter | TravisR100 | Haas Mills | 16 | 10-24-2009 05:08 PM |
| Problem- chatter | Claude Boudreau | DIY-CNC Router Table Machines | 2 | 05-23-2009 11:18 PM |
| DEEP THREAD CHATTER | shoplady#1 | Mori lathes | 23 | 01-07-2008 07:44 AM |
| Chatter | gabeless | Hard and High Speed Machining | 10 | 07-14-2005 11:09 AM |
