Old 10-22-2010, 06:23 PM
TheGreenMachine is on a distinguished road
Rigid Tapping?
When I purchased my machine they weren't sure if it had rigid tapping, we looked at the parameters and it said no for rigid tapping and we looked at the options sheet and rigid tapping was not cheked. After I received the machine I noticed that the inverter was marked RT ready. Today I was cleaning the motor fan, when I took the cowl off I noticed a encoder mounted on top of the motor. It says accu-coder and encoder on it so I'm sure its a encoder. Is this just a matter of enabling a parameter or could the machine still be missing hardware? Either way what do I need to do to enable the rigid tapping?
The machine is a VMC40 with a 88HS
Old 10-22-2010, 07:49 PM
dcoupar's Avatar
What's an 88HS?
Old 10-22-2010, 09:20 PM
Originally Posted by dcoupar View Post
What's an 88HS?
Its a Fadal control
Old 10-22-2010, 09:30 PM
SORCHEROR is on a distinguished road
if you have a tool changer you have an encoder to orient the spindle and you can tap
in the machine,i do it with mine,as long as you have a program that can do it,or you write one yourself,im not sure you can do repeat rigid tapping,i havnt tried that yet
tapping on a mini mill without rigid tapping??? mls Haas Mills 13 07-03-2009 06:43 PM
What exactly is Rigid tapping? Why people always ask does it do rigid tapping? cjchands General Metalwork Discussion 23 12-19-2008 08:19 AM
Tapping head or rigid tapping Gregory_C Syil Products 2 10-18-2008 12:49 AM
rigid tapping damon1313 Fanuc 5 07-29-2008 05:26 PM
Rigid tapping or tapping head wildcat Industrial Hobbies (Support forum) 7 09-24-2006 12:08 PM
