Old 10-20-2010, 07:45 AM
800XCR is on a distinguished road
Fanuc 0m Machine position is metric
Daewoo 850 VMC with Fanuc 0m. Onthe position screen the machine position is displayed in metric while the others are displayed in inches. How can I change the machine position to inches.
Old 10-20-2010, 07:52 AM
cnc2149 is on a distinguished road
With most Series 0 controls, you can set parameter 0063 bit 0 = 1 to have the Machine Position match the units that your part program is using.
Old 10-21-2010, 12:44 PM
Parameters displayed on screen end at 40 and start again at 100. I should have mentioned that the control is a Om model B. These parameters are not listed in the manual either.
Old 10-21-2010, 10:37 PM
LogicalFool is on a distinguished road
G20 I believe. Or is it different with the older models?
Old 10-22-2010, 07:16 AM
it looks like yours is too old to support that parameter. The 0-C and 0-D have many more parameters and it was added in this time frame.
The G20/G21 switches inch/metric Programming (ABS and REL positions) if you have the inch/metric switching option, but the Machine position will always be displayed in the same units that the parameters are in. I know that you have this option because otherwise the ABS, REL, MACH would all be the same units.
It really can be confusing to the operator to have the Machine units differ from the ABS/REL, but as you've found, the Machine unit conversion parameter does not exist on the older 0-A and 0-B controls.
Old 10-22-2010, 09:00 AM
I would like to thank everyone for their help. I've been through the parameters in the manual a couple of times and could not find anything. I also called Fanuc support about this yesterday, they couldn't find an answer right away and said they would call me when they did. So, this is not possible with our control?
Old 10-22-2010, 09:03 AM
You are correct. The only way to change the machine position units display on this older Series 0 control is by changing the parameter units (which we do not want to do because you have a metric machine) or by the parameter 0063, which came out later on.
Old 10-22-2010, 09:21 AM
ulrarrun27 is on a distinguished road
Give G20 in MDI Model.
Then Make 0 to 1 in the inch area at setting page after making parameter enable.
Switch off and ON the control.
You are done
Old 10-22-2010, 09:23 AM
the previous post shows how to change your programming units (ABS/REL). Will not change Machine units.
Old 10-24-2010, 07:58 PM
EDM_Fixer is on a distinguished road
Find the above page. And change the " input units " to " 1 ".
It is in the setting or handy pages.
I thought all OMs had this page.
GL Jim
tapping metric thread on fanuc WJ MARK G-Code Programing 6 04-28-2010 05:22 PM
Fanuc 6t Metric to Inch ? denverwelder Fanuc 5 04-26-2010 11:44 PM
Newbie- First Machine, EU, Metric or Imperial? daithi Mini Lathe 2 02-24-2009 02:00 PM
FAPT Fanuc 10T change from Metric to Engilish? slow_joe Fanuc 1 02-19-2009 09:15 AM
Need Help!- Fanuc 3TF inch/metric conversion. GPena Fanuc 1 03-07-2008 05:19 PM
