Old 10-15-2010, 07:37 AM
ggborgen is on a distinguished road
G65 macro call
Gentlemen,
I have a Doosan TT1800 with a Fanuc 18i control, and I was wondering if there is a parameter to switch so when I run a macro that it will show the macro being ran instead of just showing the G65 line and it's arguments. Thank You
Old 10-15-2010, 08:20 AM
dcoupar's Avatar
I believe parameter 3232 bit 1=1 to display 9000 programs, and bit 0=1 for 8000 programs.
Old 10-16-2010, 04:43 AM
christinandavid's Avatar
christinandavid is on a distinguished road
I run a 31i and I want the opposite - is this possible also?
DP
Old 10-16-2010, 09:21 AM
dcoupar's Avatar
DP
I don't find any reference to ND8 or ND9 in the 31i parameter manual, and parameter 3232 isn't listed. You might check your control and see if parameter 3232 has ND8 and ND9 listed for bits 0 and 1.
Old 10-16-2010, 01:44 PM
My TT1800 with the 18i control has parameter 3232 but no ND8 or ND9.
Does this matter?
Old 10-17-2010, 02:05 AM
dcoupar's Avatar
Does this matter?
On the 18i, 3232 bit 1 is ND9 and bit 0 is ND8.
I'm not sure if this is true on the 32i because the parameter manual doesn't list 3232 OR ND9 or ND8.
Old 10-18-2010, 07:36 AM
No joy on 31i...
DP
Old 10-23-2010, 10:42 AM
Question
I tried parameter 3232 and it did not work, the control is a 18i-TB if that makes a difference? Any other ideas?
Old 10-23-2010, 01:38 PM
viorel26's Avatar
viorel26 is on a distinguished road
parameter 3202 (Fanuc 18i-B)
parameter 3202 bit 0
Editing of subprograms with program numbers 8000 to 8999
0 : Not inhibited
1 : Inhibited
The following edit operations are disabled:
(1) Program deletion (Even when deletion of all programs is specified,
programs with program numbers 8000 to 8999 are not deleted.)
(2) Program output (Even when outputting all programs is specified,
programs with program numbers 8000 to 8999 are not output.)
(3) Program number search
(4) Program editing of registered programs
(5) Program registration
(6) Program collation
(7) Displaying programs
parameter 3202 bit 4
Editing of subprograms with program numbers 9000 to 9999
0 : Not inhibited
1 : Inhibited
The following program editing during operation is invalid.
programs with program numbers 9000 to 9999 are not deleted.)
(2) Program punching (Even when punching of all programs is specified,
programs with program numbers 9000 to 9999 are not punched.)
(4) Program editing after registration
Same parameter for Fanuc 32i
Old 10-23-2010, 03:32 PM
dcoupar's Avatar
My bad... I misread the Fanuc parameter manual.
Prm 3232 bit 1 should be 0 (display NOT prohibited) to display 9000 to 9999 programs. Same for bit 0 for 8000 to 8999 programs.
Name:	F18i Prm 3232.jpg‎
  #11   Ban this user!
Old 10-23-2010, 03:35 PM
dcoupar's Avatar
0 : Not inhibited
1 : Inhibited
0 : Not inhibited
1 : Inhibited
I believe these parameters only affect EDIT mode operations, NOT the display of the programs during execution.
  #12   Ban this user!
Old 10-23-2010, 08:49 PM
vincerace's Avatar
vincerace is on a distinguished road
on 18i its #3202 bit 4 =NE9(no edit 9000)
#3202 bit 0 =NE8(no edit 8000)
What do you call this? Greenbuggy Bridgeport and Hardinge Mills 2 03-28-2010 12:18 AM
Testing program for Macro (Fanuc Macro B) NickDP Fanuc 2 03-27-2009 03:15 PM
Need Help!- how do you call these? Claude Boudreau Machine Created Art 1 12-10-2008 09:18 PM
Convert Fanuc Macro to Fadal Macro bfoster59 Fadal 1 11-08-2007 11:41 PM
What would you call this? MrRage General Metal Working Machines 7 09-16-2005 03:48 AM
