Old 10-12-2010, 10:35 AM
samu's Avatar
samu is on a distinguished road
0MD black out
Spindle was in warm-up cycle, nothing was moving and suddently: Black out
Screen turn to black and spindle stop. I have no idea were to begin to trouble shoot. Any help wil be apreciate!
Old 10-12-2010, 10:39 AM
Al_The_Man's Avatar
The first thing is to use the machine schematics, which hopefully you have, to detect where and what power you have, starting with the machine disconnect switch.
Is there any LED's on or contactors picked up etc, status of fuses.
Old 10-12-2010, 10:45 AM
samu's Avatar
i found a burned fuse in the power unit. It is the AC INPUT fuse. I have no spare and dont know were to find it.
Old 10-12-2010, 12:33 PM
samu's Avatar
i replace the fuse but it's not working. The fuse don't blow again but i cannot turn on the CRT. My maintenance manual just cover 0M-C version. Anyone have a trouble shoothing manual for the OM-D?
Old 10-12-2010, 12:35 PM
Al_The_Man's Avatar
Id this is one of the small green fuses, an alternative to Fanuc would be to contact North American Industrial in Mississauga Ont.
They specialize in Fanuc repair and parts.
Old 10-12-2010, 12:37 PM
Al_The_Man's Avatar
Your power supply may be blown.
Check the DC output pins at the side of the P.S.
Old 10-12-2010, 12:43 PM
samu's Avatar
There is powersupply module and power unit AI or A1. On power unit A1 the pilot green led doesn't turn on neigther than the alarm red LED.
Old 10-12-2010, 12:48 PM
Al_The_Man's Avatar
Usually Fanuc has a power up check, the power is applied to all units and if for e.g. the power supply does not power up, the Input Unit shuts the power off, so it is a catch 22 to try and trouble shoot.
There is a service jumper on the input unit that stops it from shutting down in order to trouble shoot the system, the draw back is that if there is a short etc causing the shut down, it will be there constantly, so Fanuc advises caution when by passing the shut down.
Old 10-12-2010, 12:55 PM
samu's Avatar
where is this famous input unit?? i cannot find it
Old 10-12-2010, 01:04 PM
Al_The_Man's Avatar
I don't have the range of part numbers here and they make at least 10 different types!!
It is a small stand alone unit that has terminal strips on each edge and has a relay and two leds, red & green usually, with 2 or more fuses possibly.
Somewhere in the range of 8"x5".
  #11   Ban this user!
Old 10-12-2010, 01:25 PM
samu's Avatar
power unit A1 has some burn component inside. Where to repair or buy new one
A16B-1212-0950
Old 10-12-2010, 02:43 PM
Al_The_Man's Avatar
Try the previous mentioned, N.A.I. Missisauga.
Or ebay.
How to tell the difference in Black ABS VS Black Delrin? conceptmachinin General Material Machining Solutions 5 10-17-2011 09:43 AM
Black Marking?? Dizzy_G Laser Engraving & Cutting Machines 5 08-05-2010 01:11 PM
CRT color, became black EliseoMonteverd Mazak, Mitsubishi, Mazatrol 3 10-13-2009 07:50 PM
Jet Black Machine LLC jetblackaircraf Product Announcements & Manufacturer News 0 12-23-2008 12:41 AM
WHO Does Black PVD? mabmojo Metal Finishing and Plating 0 09-25-2008 09:56 AM
