Old 10-12-2010, 02:30 AM
kningzer is on a distinguished road
Changing the parameters for ballscrew Fanuc 15M
Hi
I need to change the ballscrew on the X axis in a Fanuc controlled machine.
The only thing is that the oitch on the current ballscrew is imperial and becaus e i live in sweden i want to have it in mm.
Where do i find the parameters for ballscrew pitch?
And does anyone know which more parameters that i have change to achieve this?
Thansk in advance
//Daniel
Old 10-12-2010, 08:04 AM
stevo1 is on a distinguished road
Model A or B?
There is more to it then just changing a parameter for a mm ballscrew. You have to take in account the stroke limit and reference parameters will have to be switched as well. I don’t know if pitch error, inclination compensation, and straightness compensation play a factor in this.
I have never switched like that so I guess I am not really the one that should be giving advice on it. I just think that there is going to be a lot more settings and adjustments that need to be done. However if you tell me the model and then PM me your email address I can probably get you the parameter manual.
Stevo
Old 10-12-2010, 09:54 AM
Al_The_Man's Avatar
See PDF.
Old 10-12-2010, 02:11 PM
Hi again
It is a B model fanuc. Yeah this is a big job to do. The thing is that the machine is for grinding flutes for cutting tools (ITM is the brand if you heard about it) and we are in a conversion process to make mm a standard in the factory.
I have the reference book and the standard fanuc manuals, but a parameter manual would be greatly appreciated.
Thanks for the pdf, i shall sit down tonight and read it through!
Old 10-12-2010, 02:34 PM
Al_The_Man's Avatar
Send me a email address by PM.
Old 10-14-2010, 07:53 AM
cnc2149 is on a distinguished road
Changing the screw parameters is difficult the first time you have to do it as it can ripple through to other parameter settings. Thankfully you have a 15 Model B so you will have flex feed parameters available. If you can post your CNC Parameters file or email them along with your new screw pitch info, I can run the numbers for you.
Old 10-17-2010, 05:13 AM
Hi
Yeah the firest time is always a b***h ^^
Okay what is the feed flex, don't think i heard about this before.
Sure ill mail you on monday with info, thanks alot
Old 10-17-2010, 07:47 PM
Flex feed consists of 2 parameters expressed as a ratio that take the place of the single value DMR that was used in the older, coal-fired controls. You only had 8 values of DMR (Detect Multiply Ratio) in most cases. With flex feed, you have many more possibilities. There are still other pitfalls so I'll have a look at the CNC Parameters. Please list the old and new screw leads in your email reply.
Old 10-21-2010, 07:33 AM
machine parameters
Hi
here is the parameter file to the machine that we should change the screw in...
http://www.netfear.net/parameters.DAT
Old 10-22-2010, 08:07 PM
Your parameters are already set up for 5mm screw on the X axis. See the parameters and calculations below:
Relevant parameters:
1002 = 0 (metric parameter units)
1004 = 0 (0.001mm LCI resolution)
1020 A3 = 88 (X axis is 3rd in the parameter order)
1807.3 = 0; 1815.1 = 0 (built-in motor feedback is used)
1820 = 2 (Actual CMR = 1)
1876 = 8192; 1891 = 12500 (1,000,000 count motor feedback)
1977 = 1 (flex feed numerator “n”)
1978 = 200 (flex feed denominator “m”)
LCI distance / rev
CMR 1,000,000 (n/m)
0.001 distance/rev
1 1,000,000 (1/200)
Solve for the Distance/rev:
Distance/rev = 5 mm
  #11   Ban this user!
Old 10-22-2010, 08:10 PM
Note: The formula spacing format doesn't appear quite after it was uploaded as it seemed to strip some spaces.
  #12   Ban this user!
Old 11-09-2010, 01:54 AM
Hi again
Sorry for the enormus delay to my answer and thank you all for your patience.
I have Changed the parameters and now and it is working fine.
Thanks for all the help, im really glad for this!!!
Changing Parameters in the Program danrudolph CNC Swiss Screw Machines 4 10-21-2010 04:03 AM
Fanuc 0M - Changing Axis Limits MotoDan Fanuc 6 07-23-2010 07:28 PM
Methods of changing parameters sinha_nsit Fanuc 0 10-05-2009 08:41 AM
Changing lube on a ballscrew Guldberg Linear and Rotary Motion 2 06-19-2009 08:55 AM
Tool changing on Kryle VMC500B - Fanuc 0M calor Machine Problems, Solutions , Wireless DNC, serial port 0 04-25-2005 02:04 AM
