Hi, I have Sliding Headstock lathe machine with Fanuc 10T controller. But frequently giving Following alarm- ADDRESS ERROR FFCDC9C FFC4E2 FFC522 and sometime, BUS ERROR FFD434 FFC496 FFC4D6 When I do Reset gives following 1 DUMP MEMORY 2 - 3 CLEAR FILE 4 SETTING 5 - 6 END IPL ? plz help to start the machine , If any procedure. thanx in advance |
| Here is the procedure for reloading all of your data. Your option parameters will have to be entered in hexadecimal format. To enter in option parameters 1) Power up machine with "-" minus and "." decimal point depressed 2) Key "99" and "Input" 3) Key in "3" or whatever # axes in parameter 9000 @ "AXIS" prompt 4) Step through options by number and key new Hexidecimal codes and "input" option 1=9100, option 2=9101 ect. Just push input if no change is required 5) If "clear files" appears, hit "Y" - will erase programs etc. 6) When 1st menu appears, key "6" and "enter" Once complete then enter in all of your PMC data. Timers, counters, keeprelays etc. Then setup your RS232 parameters and load the NC parameters along with programs and any offsets. Stevo **Edit** sorry forgot to mention that you may have to do a master clear the files before doing the above by holding down "7" and "9" at power up then press "99" and "input" when the IPL menu appears. It will ask to clear, press "Y". Last edited by stevo1; 10-12-2010 at 08:16 AM. Reason: clearing |
| X & Y address | Ashish B | CNC Machining Centers | 2 | 03-23-2010 10:25 PM |
| HELP! G100 IP address | noyloj | G-REX | 0 | 12-13-2009 03:54 PM |
| Need Help!- address code error! | sridhartsr | Mazak, Mitsubishi, Mazatrol | 2 | 03-27-2009 12:27 PM |
| Tape Drip feed on Meldas50 - P32 Address Error | firechcken | Machine Problems, Solutions , Wireless DNC, serial port | 5 | 05-26-2008 09:16 AM |
