Old 10-06-2010, 10:25 AM
eh1203 is on a distinguished road
Angry yang smv 600
i went to do a tool change and the carousel kept spinning around until alarm 1007 appeared. now the spindle is above the carousel like its doing a tool change .
Old 10-06-2010, 07:08 PM
GPena is on a distinguished road
What control does your machine has?
Old 12-05-2010, 07:02 AM
bmicad is on a distinguished road
Yang help
I know itsa little late, but have you fixed this? It's probably one of the three (usually blue) prox sensors that is failing to send a signal. I think you can look at x16.7, 17.7 and 18.7 to see which one. if you haven't fixed it and still need help, I can look up exactly which one when I get back to my shop
-Brad
Old 04-11-2011, 02:40 AM
Otso is on a distinguished road
Greetings from Finland. I have the same problem. We use Fanuc series 0-MD interface. Apparently the problem is with the proximity sensor also. Model Yamatake-Honeywell FL2S-4J6HD-R5. Problem appeared when changing tool. Whole thing froze and error 1007 appeared. We also thought that the problem could be that the M06 code is active. The problem is that we don't have the original manuals, but only translated ones that don't appear to have all the info we need. Also, it's probable that the main problem is sensor X16.7. If there're any suggestions, I'd be happy.
Need Help!- Yang VMC MV3A susiem General CNC (Mill and Lathe) Control Software (NC) 1 08-24-2009 12:37 PM
Need Help!- YANG VMC1000 OM-D Toddxmann Fanuc 17 08-04-2009 06:59 PM
Need Help!- Yang ML-25A Billet Sean General Metal Working Machines 1 04-22-2009 03:48 PM
yang growl BAD DOG Machine Problems, Solutions , Wireless DNC, serial port 1 02-16-2007 02:11 PM
