Old 10-03-2010, 01:16 AM
Ingmar Trobäck is on a distinguished road
Question Read D-parameter in CNC-programme
Can someone please advice me how to read PMC-parameter "D-type" in a NC-progamme? It´s for a Fanuc 31i.
I would like to use this external bit information in a macro, calculating variables.
Thank you!
Old 10-04-2010, 03:30 PM
tmbruno28 is on a distinguished road
you can only read data parameters through your ladder programm using special instructions.So only one modification of your ladder programm can help you using window(sub 51 or sub 52 i think)
Old 10-06-2010, 04:54 AM
Thank you,
I have got an answer from another source.
It turns out to be readable by using "G340 Fn. An. Qn. ;"
Where:
"F" specifies numbers of bytes:
F0.=bit, F1.=1byte, F2.=2bytes, F4.=4bytes
"A" specifies adress:
A0.=R, A1=D, A2=C, A3=K, A4=X, A5=Y, A6=F, A7=G
"Q" specifies adress number
e.g. G340 F0. A0. Q128.3 ; Reads status of R128 bit 3
G340 F2. A1. Q80. ; Reads status of D80 (2 bytes)
The value is written to macro variable #100 which can be used in the NC-programs.
Hope this will be useful to other programmers as well.
/Ingmar
Old 10-06-2010, 05:40 AM
sinha_nsit is on a distinguished road
Does it apply to 31i only?
Old 10-06-2010, 06:20 AM
No.
I am quite sure it is working in Fanuc 16i/18i/30i as well.
Old 10-06-2010, 07:31 AM
christinandavid's Avatar
christinandavid is on a distinguished road
How is your program using this data? Just curious...
DP
Old 10-06-2010, 12:50 PM
In this case we thought of using some externaly set D-parameters as a code for calling up different machining programs from a network.
There is a robot loading the machine with different articles and it can set these parameters externaly. Then we can call the requested program with this code.
G340 A F Q
M198 P#100
M30
There are naturally a lot of other examples one can think of using different status of parameters, e.g. jump in programs depending on situation.
Old 10-06-2010, 08:04 PM
Sounds extremely complicated. I'm already up to 100 variables just to automatically time shifts and cycle processes...on one machine.
Would it be simpler to program another robot with a large whip attachment to whip the robots in question until they get their act together?
DP
Old 10-07-2010, 04:04 AM
viorel26's Avatar
viorel26 is on a distinguished road
G340
Where can I find more details about the G340
can we read the current status of a parameter sinha_nsit Fanuc 12 12-07-2009 06:44 AM
Need Help!- How do I read the value of an F-type parameter into a macro variable? Jan d. Mazak, Mitsubishi, Mazatrol 24 02-17-2009 10:47 PM
3d scanner cad/cam programme paul h General CAD Discussion 2 11-25-2008 04:23 PM
slotting programme davedoubleu Haas Mills 3 09-27-2007 02:42 PM
plc programme mohd khalid PIC Programing / Design 1 05-07-2007 03:36 PM
