I'm installing a machine and the machine will allow the axis to crash into the tool carousel. Normally the builder sets this up in with the position switch function.(Parameter 6901-6999) These parameters are set with some values and typically if you moved the axis into the tool change area it would set an overtravel alarm. This is not the case. Does anyone have an explanation of how this works and how to set it up? |
| I have never used that function, but reading through it it seems to imply that if a 10 posn switch is input to the PMC the switch position will select the axis and minimum/maximum position of that axis by parameter? How far did you get with testing it this way? Al.
They are using the following values: 1240=1784485 1st ref position 1241=1981000 2nd ref position for toolchange 1320=1990000 x-axis plus limit 6901=0000 0010 6910=1 X-axis 6911=2 Z-axis 6912=1 X-axis 6913=2 Z-axis 6930=198100 6931=-146790 6932= 198100 6933=-146790 6950=198000 6951=-145000 6952= 198000 693=-145000 |
| The only 18i manuals I have are for the 18iL & P, the parameters are all 5 digit instead of 4? I checked the regular 18 manual and it shows what appears to be the same description as you have, the only thing is that 6901 only shows valid entry for the first (least significant bit) IGP being 0 or 1, (bit entry rather than byte for this address)? Al.
They have assigned F70.0, 1, 2, 3 to switches 1-4 after further checking the F address is not in the ladder they are assigned but were not used , so I think this is the problem. |
| Newbie- Interfacing 3 Position Rotary Switch with Cycle Jog Step Function | MRM RCModels | Mach Software (ArtSoft software) | 1 | 01-24-2010 06:34 AM |
| Home position proximity switch | scrambled | General Electronics Discussion | 0 | 02-25-2009 12:13 PM |
| Need Help!- 4 Position Rotary Switch | Shanghyd | General Electronics Discussion | 4 | 04-06-2008 10:39 PM |
| M function feed hold tell switch trips? | D.D.Machine | TurboCNC | 1 | 11-28-2007 11:34 AM |
| Home switch position | MrBean | DIY-CNC Router Table Machines | 1 | 12-16-2004 06:00 PM |
