Old 09-29-2010, 02:31 PM
ProToZyKo is on a distinguished road
Angle drilling lathe
Hi
Im wondering if there's any G code to turn the coordinate system a specific degree to make it go in Z and X to drill a hole with a angle head.
Sure i could calculate the coordinates but would be much easier if such a G code exists Also easier to check if the angle head is set right to be able to use HM drills.
Example G00 Z5. X100.
G## 30 degrees
G81 X80
It would drill to X80. and Z# in 30 degrees.
Fanuc 18iTB
Old 09-29-2010, 08:03 PM
houstonsamuel is on a distinguished road
what kind of machine are you doing this on? Also have you checked the FANUC operators manual? If you have one.
Old 09-29-2010, 09:44 PM
dcoupar's Avatar
G68 (G68.1 on some sytems) Coordinate Rotation. What machine make & model are you using?
Old 09-30-2010, 02:56 AM
Thank's for reply
Machine Omega OM-80
Im not in the machine atm, i wasn't sure this was even possible so i haven't checked the manual since it's kinda hard to read
Can't really stop it for too much testing, how would the line go?
Old 09-30-2010, 10:43 AM
dcoupar's Avatar
First of all, be aware that G68.1 is an option, and it may not be turned on in your control.
The attached .jpg shows the command format.
Name:	Coordinate Rotation Format.jpg‎
Old 09-30-2010, 04:13 PM
Looks like this is something i don't have
What would you guys prefer? Calculating the coordinates by hand/edgecam, upgrade to get that option, upgrade to Manual Guide I.
If something should go wrong we can't really take the drill out in manual mode without this option :s
We are considering Manual Guide I, kinda hard to get any info on how good it is, im used to FAPT and Okuma's IGF, and if manual guide i is as easy and good as that i can't see any reason not to buy it.
We mostly program simple part, big machine and only 3 axis so not that advance.
I would think that Edgecam would be slower to program our part's and changing cut depth, feed rates and speed.
Anyone with any experience?
Old 09-30-2010, 05:34 PM
CNCInnovations is on a distinguished road
Optionally the Fanuc lathe controls can use an angle command. Either the X or the Z command can be replaced by an A command.
Instead of:
G0 X50. Z2.
G1 X13.05 Z-30.
You can program:
G0 X50. Z2.
G1 A210. Z-30.
Or:
G0 X50. Z2.
G1 X13.05 A210.
A+ is Counterclockwise from the 3 O'clock position. A- is Clockwise from the 3 O'clock position. A0 is or Z+ direction. A90. or A-270. is the X+ direction. A180. or A-180. is the Z- direction. A270. or A-90. is the X- direction. The A command can be programmed to the 3rd decimal place (A12.345).
I hope this helps.
CNCInnovations
Old 10-01-2010, 07:17 AM
sinha_nsit is on a distinguished road
Is it a combination of zero shift and rotation?
Old 10-01-2010, 08:59 AM
dcoupar's Avatar
Yes, it is.
Old 10-01-2010, 01:26 PM
G0 X50. Z2.
G1 X13.05 A210.
Would only make it go in X direction.
What's the best option? Upgrading to Manual Guide I and G68.1 or use edgecam?
We have allot of different part's and we need to best way to program.
r-8 right-angle drilling attachment norvil1 Tormach PCNC 2 03-31-2009 08:09 PM
Need Help!- Right angle drilling m3 holes in enclosure contour General Metalwork Discussion 6 03-27-2009 03:32 AM
variable angle drilling head kendo Haas Mills 21 12-12-2008 10:46 AM
Need Help!- drilling in angle(oblique) crish Okuma 1 05-12-2008 11:37 PM
peck drilling at an angle... metalmansteve G-Code Programing 3 10-27-2006 03:13 AM
