Old 09-25-2010, 07:14 PM
alaih17 is on a distinguished road
Fanuc A20B-0008-0410 (6M Master)
1. Does everybody know the Circuit diagram/ Wiring Diagram of Fanuc A20B-0008-0410 ?
2. Can Fanuc A20B-0007-0061/1A be used on Fanuc A20B-0008-0410 (6M Master) as 20mA/RS232 Converter?
3. Can Facit 4070 be connected to PC and on what port ?
Old 09-27-2010, 02:22 AM
gbowne1 is on a distinguished road
I've been working on the various 6M and 6T configurations there are, including the B model version.
Here is what I have in my system.
A20B-0008-0410/08D Masterboard
A20B-0008-0430/03A CRTC/Puncher
A87L-0001-0016/11H 64-2 BMU
A20B-0008-0440/03A PC Model B
A20B-0008-0480/03A ROM
I don't know if the A20B-0007 boards work or if those are for the 6M. I have seen a couple A16B-1200-0150 ROM boards on some configurations.
I also have the following boards:
A20B-0008-0461 Res/Ind
A20B-0008-0470 Add Axs
and I just received the other day A20B-0008-0490/02B
Any one want to help with my configuration?
The servos are FANUC Yellow cap 10M DC servos. A06B-0651-B012 or -B212.
Plan on getting one of the A06B-6044 or 6045 and 6047 VCU's including the spindle one and the -H050 discharge unit.
I also see that there is a A20B-0007-0010 Masterboard. Which model is that for? There are boards that go with that too.
The A16B 1200 boards for the 6 must be a level up version of some boards.
Greg
Old 09-27-2010, 10:16 AM
memoryman is on a distinguished road
1: We have the diagrams for that motherboard.
2: the Facit punch can be connected to the connector on the crt/puncher board
3: there are no boards specific to a lathe or machining center; software decides what the control does.
4: you maintenance/connections manual tell you various configurations
5: are you with IPTN in Bandung? We are helping them already.
Old 09-27-2010, 09:26 PM
Are there any other boards in my configuration?
I cannot find my 6M manuals.
Greg
Old 09-28-2010, 08:17 AM
resolver/inductisyn interface a20b-0008-0461 and MMC interface a20b-0008-0500. There is a complete system on Ebay item #140459126903 loaded.
Old 09-28-2010, 11:15 AM
I am not on IPTN Bandung, I am on PT Kedawung Surabaya, can you give me
diagram of CCx1 port (50 pin) of fanuc A20B-0008-0430/03A ?
Old 09-28-2010, 12:04 PM
1: TTY1-2: TTY2-3: TTY3-4: 0v-7: PR-8:TE-9: ERR-10: +6V-11: CH1-
12: CH2-13: CH3-14: CH4-15: CH5-16: CH6-17: CH7-18: CH8-32: 24V
34: RS-35: CS-36: DR-37: 0V-38: CD-39: 0V-40: SD-41: RD-42: 0V-43: ER
46: SD-47: 0V-48: CH9-49: PI-50: SG
OTHER PINS NOT CONNECTED.
Old 09-29-2010, 04:57 AM
Thank's for all helps, now I can make connection between PC to Fanuc and otherwise (Fanuc to PC). Test run CNC machine, and the result is OK. I use Fanuc CRTC/Puncher A20B-0008-0430 to connect to PC.
Old 10-26-2010, 08:40 AM
lmostafa is on a distinguished road
Hello
I want to change a card for a A20B-0008-0410/08D moriseiki TL1
I have a backup machine parameters and the pitch error pc param
I want to know if i change dhis card without introducing param
Best regards
Need Help!- Fanuc VFD A20B-6060-H008 cha lee Fanuc 0 05-08-2009 09:59 AM
Need Help!- CN1-CN7 Cable Detail on DC Spindle Servo A20B-0008-0373 parametric.ms Fanuc 0 04-07-2009 01:32 PM
Fanuc Drive/Servo (A20B) Question Death Adder Fanuc 9 04-09-2008 09:42 AM
looking for a 6ta master board a20B-0007-0010 ezjn Fanuc 3 05-27-2007 06:21 PM
Fanuc 6M-B DC Spindle Board A20B-0008-0378 Manual/Drawings TFGC Fanuc 0 01-15-2007 01:37 PM
