Old 09-23-2010, 04:10 PM
crazycnc is on a distinguished road
programming a loop
Hello all,
I am running a Takisawa EX-110 lathe with a Fanuc 21i-T control. This is my program:
:0100
M98P0101
M98P0102
M98P0103
M30
What I want to do is loop through this program a specific number of times, (say 35 times) and then stop. I know you can use macros to create loops and logic and such but I have never used them. Could somebody help me with this problem?
Thanks a lot!
Old 09-23-2010, 04:17 PM
beege's Avatar
beege is on a distinguished road
Originally Posted by crazycnc View Post
Hello all,
:0100
M98P0101
M98P0102
M98P0103
M30
Thanks a lot!
So many ways to skin this cat!
You could write a short program:
:O1000
M98P0100L#500
M30
You'd have to end your original program with an M99 instead of an M30.
Then, enter the number of repetitions into your Macro Variable table at #500.
Not sure about the format for repetition values in the M98 line. Some controls are different there. Also, there's a limit to the depth of nested programs, so if you have subs in your subs, this might be problematic.
Old 09-23-2010, 04:40 PM
ok, thanks that makes sense. Now I'm trying to figure out how to set or even how to access my variable table....
Old 09-23-2010, 04:48 PM
ok, I found my variables. I would like to keep it all in one program if possible. If I were programming my computer, I would do something like this:
:0100
for(int i = 0; i < =35; i++) {
// call program 101
// call program 102
// call program 103
M30
Can I do something similar on the lathe?
Old 09-23-2010, 04:50 PM
christinandavid's Avatar
christinandavid is on a distinguished road
#500=1
WHILE[[#500]LE[35.]]DO1
M98P101
M98P102
M98P103
#1=#1-1
END1
Just change the 35 to however many repeats you need. Set #500 in program. Just make sure your sub programs don't use #500 or WHILE loops...
DP
Old 09-23-2010, 05:06 PM
#1=#1-1
Should this be #1=#1+1? I am assuming 'LE' is 'less than or equal'?
Old 09-23-2010, 05:12 PM
Yep, you are quite correct, er, looks like I changed my mind halfway through didn't I - sorry 'bout that one.
DP
Old 09-23-2010, 05:17 PM
:0100
#500=1
WHILE[[#500]LE[2.]]DO1
M98P101
M98P102
M98P103
#1=#1+1
END1
I ran this program and it didn't stop after 2 parts, just kept on going. I have to leave now, I'll be back in the morning. Thanks for all your input so far, might have a few more questions tomorrow.
Old 09-23-2010, 05:29 PM
Aaaaah yes. I appear to have changed my mind twice in my original post...
Change it to #500=#500+1 and all will be well.
Made myself look a right clown there eh? I changed from local macros #1-#33 to common macros #500+ as I wasn't sure if the locals would be affected by jumping in and out of main program.
More often than not I spend longer debugging my programs than coming up with the original concept....
DP
Old 09-23-2010, 05:50 PM
beege's Avatar
Originally Posted by christinandavid View Post
#500=1
M98P101
M98P102
M98P103
#1=#1-1
END1
DP
Likewise,
:O0100
#500=#500+1
IF [#500 GT 35] GOTO N999
M98P101
M98P102
M98P103
M99
N999M30
  #11   Ban this user!
Old 09-23-2010, 06:14 PM
Damn, couldn't find a single mistake in your post, am I the only one with poor brain/finger co-ordination ('co-operation' may be the right word in my case)?...
Of course the GOTO method would also be the best way to go if you wanted to eliminate the need for sub programs.
DP
  #12   Ban this user!
Old 09-24-2010, 02:58 AM
Fanuc Mate's Avatar
Fanuc Mate is on a distinguished road
Hello.
Christian is right with his method. The only thing is though, 500 variables are not cleared until they are physically changed. Therefore use 100 variables.
:0100
WHILE[#100LE35]DO1
M98P0101
M98P0102
M98P0103
#100=#100+1
END1
M30
Fanuc Mate
Open Loop to Closed Loop Stepper Conversion beamhome Stepper Motors and Drives 9 05-24-2012 02:46 AM
Newbie- CNC conversion typically open loop or closed loop? foobar42 Benchtop Machines 8 10-29-2009 07:21 PM
question on closed loop vs open loop (servo systems) boonie Servo Motors and Drives 20 11-09-2007 12:30 PM
Closed loop vs. open loop pelesl Benchtop Machines 10 04-06-2007 04:56 PM
Lathe conversion - open loop vs closed loop bhowden General Metal Working Machines 7 03-21-2006 03:56 PM
