Old 09-21-2010, 08:21 PM
stucaruk is on a distinguished road
Fanuc A06B-6096-H106 Fan replacement
We're trying to get a Kitamura HX400i up and running that led a previous life well lubricated but never cleaned. There is coolant mist goop everywhere, and it's not as bad inside the electronics cabinets except around anything that has a fan. The fans a filthy and full of gunk.
We got all kinds of amplifier alarms as we tried to power up, several related to the amplifier fans. We kickstarted the fans with an air blowgun to bring them to speed and we're mostly running except for an intermittent IPM fault on the V axis amplifier.
I'd like to clean the fans, but don't want to pull the amps and lose the absolute position data stored by the batteries. Is there a simple way to just pull the fan for cleaning on the amplifiers, like on certain other models?
Anybody got a service manual in pdf form for a Fanuc A06B-6096-H106 amplifier?
Thanks,
Stu
Old 09-21-2010, 09:52 PM
arpit is on a distinguished road
search on google u will find it very well..
Old 09-21-2010, 10:40 PM
Evidently Google must work better in India. I always use Google first and generally do quite well. After wading though dozens of pages of Fanuc A06B-6096-H106 hits, I can tell you lots of places to buy another amp, but none that tell me how to service one.
Do you work for Microsoft tech support by chance? You answer is about as useful as something they would provide...
Old 09-22-2010, 10:30 AM
kcho is on a distinguished road
Try here.
http://support.ge-ip.com/support/res...FZ65165E02.pdf
Best regards
Carlos Cabrera
Old 09-22-2010, 01:42 PM
Thanks!
Evidently the amplifiers need to come out which means I'll lose the absolute position data and have to rehome all the axis. I guess I need to find a tech brief that tells me how to home these out after losing the encoder data before I go much further.
Thanks,
Stu
Fanuc replacement Machinist3 Fanuc 18 03-13-2010 01:52 PM
Need Help!- Alpha Series Servo Amplifier A06B-6079-H106 M.RISHIKESH Fanuc 0 11-24-2009 09:12 PM
Problem- Oops.., Fanuc AC spindle, A06B-6060-H008 cha lee Fanuc 3 06-10-2009 08:28 PM
Fanuc A06B 6064 C312 Spindle drive jkford96 Fanuc 5 02-20-2007 09:16 PM
Fanuc ac A06B driver mariusborza Fanuc 5 10-26-2006 04:25 AM
