Old 09-20-2010, 06:25 AM
W00dM@n is on a distinguished road
Macro B Newbi
I use Router-Cim to create g-code for the Komo router. I am in cabinet construction. I recently started looking into Macro B programming and can not get this to work. All I want to acheive is for the operator to fill in x dim y dim and qty of rectangles to cut. here is my code
:01(MACRO TO CUT MULTIPLE RECTANGLES ON 0.725 THICK PLYWOOD)
G00G17G20G28G40G80G91Z0M5
G90
G52X0Y0Z0
G08P1
M08
(ROUTER-BIT .375 DIA.)
G28G91Z0M05
G90T2001M06
T102
M03S16000
G00G17G55X.0635Y1.9198
G00G43H1Z.975
G65 PO100 Y4.0 X36.0 Q4(THIS LINE Y4 IS WIDTH OF PART_X36 IS HOW LONG THE PART_Q4 IS HOW MANY PARTS)
G28G91Z0M5
G28G91X0M09
G90
G52X0Y0Z0
G08P0
M30
O100(Begin Sub Program)
#100=0
#101=0.0(ZERO POINT X)
#102=0.0(ZERO POINT Y)
#103=#17
#104 = #25
#105 = #24
WHILE [#100 NE #103]DO1
Z.825
G42D01G01Y#3+1.7135F375.
Y#102+.0635Z0.
X#105+.4365F750.
Y#104+.4365
X#101+.0635
Y#103+.0635
X#101+.4385F750.
X#101+2.0885Z.825
G00Z.975
G40G00X#101+2.2948
#100=#100+1
#102=#102+#104+0.5
END1
M99
Here is the error
127 nc, macro statement in the same block
Can anyone point out where I am failing?
Old 09-20-2010, 07:43 AM
christinandavid's Avatar
christinandavid is on a distinguished road
[QUOTE=W00dM@n;826453]I use Router-Cim to create g-code for the Komo router. I am in cabinet construction. I recently started looking into Macro B programming and can not get this to work. All I want to acheive is for the operator to fill in x dim y dim and qty of rectangles to cut. here is my code
G90
G52X0Y0Z0
G08P1
M08
G28G91Z0M05
G90T2001M06
T102
M03S16000
G00G43H1Z.975
G65 P100 Y4.0 X36.0 Q4(THIS LINE Y4 IS WIDTH OF PART_X36 IS HOW LONG THE PART_Q4 IS HOW MANY PARTS)
G28G91Z0M5
G28G91X0M09
G90
G52X0Y0Z0
G08P0
M30
O100(Begin Sub Program) Your sub should be a separate program
#100=0
#103=#17
#104 = #25
#105 = #24
Z.825
G42D01G01Y#3+1.7135F375. Should this be Y#103?
Y#102+.0635Z0.
X#105+.4365F750.
Y#104+.4365
X#101+.0635
Y#103+.0635
X#101+.4385F750.
X#101+2.0885Z.825
G00Z.975
G40G00X#101+2.2948
#100=#100+1
#102=#102+#104+0.5
END1
M99
%QUOTE]
Also use [] a bit more often to keep things orderly - I once had a macro that was trying to look for #3.5....(#7/2)
DP
Old 09-20-2010, 08:56 AM
Smile
I see the errors, thank you . I will try it and see.
Old 09-21-2010, 08:01 AM
sinha_nsit is on a distinguished road
Use square brackets everywhere:
G42D01G01Y[#3+1.7135]F375.
Y[#102+.0635]Z0.
X[#105+.4365]F750.
Y[#104+.4365]
X[#101+.0635]
Y[#103+.0635]
X[#101+.4385]F750.
X[#101+2.0885]Z.825
G00Z.975
G40G00X[#101+2.2948]
Old 09-22-2010, 10:32 AM
Sorry, but I'm struggling and learning
To save the sub as separate program does the name of the file need to be 100 or O100? or can it be anything. Is the following good?
#100=0
#103=#17
#104=#25
#105=#24
WHILE [#100NE#103]DO1
Z.825
G42D01G01Y#103+1.7135F375.
Y[#102+.0635]Z0.
X[#105+.4365]F750.
Y[#104+.4365]
X[#101+.0635]
Y[#103+.0635]
X[#101+.4385]F750.
X[#101+2.0885]Z.825
G00Z.975
#102=[#102+#104+0.5]
#100=[#100+1]
END1
M99
Old 09-22-2010, 11:08 PM
You can choose any number between 1 and 9999.
If you choose 100, the first line of the program should be O100 or O0100.
(Note the difference between O and 0)
It is called (once) by P100 or P0100
Correction:
G42D01G01Y[#103+1.7135]F375.
Correct, but brackets not needed:
#100=[#100+1]
Hello from another newbi Rik H Europe Club House 4 09-18-2010 06:57 PM
Need Help!- Newbi Help please Parameter List slant turn 30 TOBYC Mazak, Mitsubishi, Mazatrol 0 05-24-2010 04:03 AM
Testing program for Macro (Fanuc Macro B) NickDP Fanuc 2 03-27-2009 03:15 PM
Jeep Fender Flares (newbi q's) jdougn Vacuum forming, Thermoforming Etc 28 10-06-2008 08:44 AM
CNC Newbi, What software do I need? Blacksunshine DIY-CNC Router Table Machines 2 02-15-2007 11:12 AM
