Old 09-17-2010, 06:17 PM
wildhorsemfg is on a distinguished road
buffer overflow
most of the time when i try to upload a program into my 11m control
i get this error
SR824 Buffer Overflow (rs232c_1)
what causes this ?
and how can it be fixed ?
thanks
cody
www.wildhorsemfg.com machinist / gunsmith
accumax with Fanuc 11M , Harding retrofit (working on)
Old 09-17-2010, 08:15 PM
timlkallam is on a distinguished road
Your computer is feeding code to the machine way faster than it can handle.
Slow it down ,your software should have a setting to let you pause it a few mlli seconds between blocks so your control can handle it
Tim
Old 09-17-2010, 08:21 PM
ok , ill try that when i go back to the shop
that makes sense , it used to work fine so something must of changed
i am using Cimco to upload btw
cody
Old 09-18-2010, 01:19 PM
yes that worked , thanks
it actually didnt have any pause time , so i put 50ms to be safe lol
cody
Old 09-19-2010, 03:45 AM
dcoupar's Avatar
Usually you can eliminate buffer overflows by going into Control Panel, System, Hardware, Device Manager, and opening the properties for your COM port. Back the sliders way down and uncheck "Use FIFO buffers"
FANUC 15M SR844 BUFFER OVERFLOW (3) andre324 General CNC (Mill and Lathe) Control Software (NC) 2 03-04-2010 04:06 PM
Need Help!- Buffer overflow OKUMAN Okuma 3 02-08-2010 02:53 AM
Problem- OVERFLOW HAAS VF3 daytona81 Haas Mills 4 05-04-2009 05:41 AM
Fanuc 10M Buffer Overflow nastek Fanuc 5 04-30-2009 07:15 AM
SR 834 Alarm Buffer Overflow 2 When Dripfeed TWyatt9 Mori Mills 3 03-26-2008 10:47 PM
