Old 06-14-2005, 04:14 PM
krustykrab's Avatar
krustykrab is on a distinguished road
FANUC 21i-mb
Does anyone use the mirror switch in the parameters page?
I tried to use it to mirror a hole pattern for a base and it seems that it was mirroring the machine coordinate postion, so the machine tried to take off the wrong direction and hit the x-axis limit...the axis I was trying to mirror.
I was instructed to edit my toolpaths with M95 FOR X-AXIS MIRROR, or M96 FOR Y-AXIS MIRROR directly after a move to the position about which I would like the mirror to take place. Then, at the end of the toolpath, add a move to the same mirroring postion, followed by a M94 to cancel the mirror.
The switch would be quicker.......if it worked only on the absolute coordinates.
"'Tis a poor workman who blames his tools."
Old 06-14-2005, 05:46 PM
Chris D's Avatar
Chris D is on a distinguished road
Keep in mind, when you toggle that mirror image setting in the settings screen, you are mirroring the entire coordinate system. In general, it is not a good feature to use. It is also a VERY bad thing to use mirror image when milling and using tool radius compensation.
Editing in those few M-Codes should only take you about 1 minute if you are a slow typer, so have at it.
Chris
Old 06-15-2005, 05:49 AM
krustykrab's Avatar
True Chris, I don't mind typing in the M-codes if it will save me from screwing things up. I can't imagine why anyone would require the entire coordinate system mirrored.
Off topic, this is my first time using a Fanuc controller.....with little training of course. Pretty sad, buy a brand new machine and the training I get is 2 hours with a local cnc machinist who doesn't even know how to use the drilling cycles.
I found that it was quite close to the Fadal except instead of a P value on the drill line, you have to enter a parameter in the parameters page.
Perhaps you wouldn't mind answering one more question...(probably 100 more in the future). When entering data in the parameters page, does the controller move the decimal places? For instance if I want a d-value of .5mm in my G73, would I enter the value in Parameter-5114 as 5000, 500?
Thanks for your help.....it is...priceless.(not cheap)
Old 06-15-2005, 08:11 AM
Chris D's Avatar
Yes,
I believe you have it right. Even within the CNC program, there are some addresses that don't allow decimal points. So be sure to look the the programming manual that came with the machine (as well as the parameter listings). As you suspected, assuming inch mode, the least input increment is .0001" so....
10000 = 1.0
01000 = .1
00100 = .01
00010 = .001
00001 = .0001
Leading zeros shown only for clarity in the above example.
Chris
Old 06-15-2005, 11:11 AM
krustykrab's Avatar
thanks, your a great help
Old 06-15-2005, 11:16 AM
Al_The_Man's Avatar
Does the 21i mb have the prgrammable mirror image G50.1 G51.1 like the 15MA ?
I have not used it yet but it looks like it would be useful, you can specify the mirror line across the axis you wish to mirror.
Old 06-15-2005, 12:19 PM
krustykrab's Avatar
Here is a sample of a drilling cycle with the mirror.
Name:	FANUC MIRROR_intruction.jpg‎
Fanuc 3M DNC operation max_c General Metal Working Machines 3 07-04-2010 08:11 PM
Fanuc 0-2000M DC servo motor ?? jevs General Metal Working Machines 2 02-14-2008 02:27 PM
Fanuc motor ??? jevs Servo Motors and Drives 3 03-16-2005 05:47 PM
Fanuc 21-GA_416 Alarm-Axis Disconnect lasermike Machine Problems, Solutions , Wireless DNC, serial port 0 03-10-2005 01:49 AM
FANUC coding compatability?? m1911bldr TurboCNC 3 04-24-2004 06:10 PM
