| Dear all I have Daewoo PUMA 10 lathe with fanuc 6T control. machine is working ok. i want to change the parameters like softlimt for X and Z axis . Please give me the procedure to edit the machine parameters . I will be very greatfull to you. Regards Reddy |
| Set ENABLE switch on main PCB, Set to MDI select PAR page set parameter and push INPUT. Al.
| I tried with setting the parameter write enable switch and system is showing the alaram 100 and set the selector in MDI mode and try to change the valve, but the system is not accepting any value. I am unable to enter more than 4 letters , the system is not accepting any value. I wanted to change the X - & Z- Limit value i.e parameter No 147 Plaese suggest me to proceed further Regards Reddy |
| This method has always worked for me? I confirmed the sequence as per the manual. Are you sure you are in the right parameter page? Not diagnostic or anything? Al.
| Thank you very much for your quick reply. I followed the same as you expalianed and i am in the PAR page only. is any parameter number to be edited before editing other parameters ? I tried By selecting all the modes one by one ,but i am not able to edit the parameters Is there any other method ? please suggest me Regards Reddy |
| Fanuc 6M machine parameter | gowthu | Fanuc | 4 | 08-12-2010 09:38 AM |
| Machine parameter for Fanuc 6t | Mostafa Mohamad | Fanuc | 13 | 05-23-2010 08:45 PM |
| edit key offset parameter | mcash3000 | General CNC (Mill and Lathe) Control Software (NC) | 2 | 06-28-2009 09:54 AM |
| fanuc oi-mc system parameter help leadwell machine | mcash3000 | General CNC (Mill and Lathe) Control Software (NC) | 2 | 11-06-2008 09:58 PM |
