Ok, so as per this thread: http://www.cnczone.com/forums/showthread.php?t=111068 Ok, so I am following the advice that Al the man had given me. And I cannot get it to respond. Here is a video of my problem. YouTube - MVI 0322Thanks, for the help guys. |
| The last time I saw the photo of your MB it showed E on the seven segment display, if it is still there, you still have a hardware/firmware problem. This is System Error: Cause: Master PCB, NC software ROM or RAM board. Al.
| For the sake of having to read the 4+ pages of posts I have a few questions. Providing it is not a hardware problem as Al has stated have you tried doing any of the master clears? To do a master clear power on with "7" and "9" depressed IPL screen will appear press "99" "Input" clear "Y" then it will ask you axis. This is the number in #9000 next it will ask you option #1? press "Input" Press "Input" through all options. Should only be 32 options It will ask to clear data or memory hit "Y" Then select option "6" to exit IPL To clear and set FAPT side. Power on holding the "BS EOB" button FAPT screen will appear. Press soft key "AUXULIRAY" Type in data "CFINT" press input It will ask yes or no to initialize press "1" for ok and input Screen will message you when complete To enter in option parameters 1) Power up machine with "-" minus and "." decimal point depressed 2) Key "99" and "Input" 3) Key in "3" or whatever # axes in parameter 9000 @ "AXIS" prompt 4) Step through options by number and key new Hexidecimal codes and "input" option 1=9100, option 2=9101 ect. Just push input if no change is required 5) If "clear files" appears, hit "Y" - will erase programs etc. 6) When 1st menu appears, key "6" and "enter" Stevo |
| Yeah, Stevo1 has the right information. I found some more notes on the web on your problem. http://www.cnczone.com/forums/archiv...hp/t-6252.html http://cncforums.machinetoolhelp.com...bel-error.html http://gefanuc.bnsi.net/eforum/showthread.php?t=13140 I was looking for others but these might help and there might be others on those other forums. Greg |
| Ok, now I have a 1 on the 7 seg display. Ok, now I am trying to enter parameters. I go to the 8000 parameter, and type 1 then imput, so it will unlock the parameters, but in purple letters, it says write protect. I have the write protect keyed switch to the opposite way of lock. Any Ideas? |
| Do you have your option parameters entered? You need to make sure that you are setting the PWE bit in parameter 8000 under the “settings” softkey and not the “service" softkey. You may also have to be in Estop mode. Stevo |
| Ok, you were correct, I was trying to enter parameter 8000 in the service, not the settings. Ok, now I got all of the parameters entered, as well as the keep relay, timer, data table control. Sure alot of info there. Anyways, I set setting 8000 back to 0, powered the machine down, and back on, and am getting an error, or E95, on the fapt side. I cannot get the machine to do anything at all. The little alarm led is on, but in the nc part of it, under the alarm, there is no alarm. Any Ideas? |
#10
| Ok, I have done a FAPT clear. Now the FAPT is fully functional it appears, it shows material types, and shapes to machine. The error was like this: *E95 C-Ram Parity Error (high):80000 Now once I did the FAPT clear, the fapt seems to be ok, But I still have the alarm LED on. I cannot find any alarm in the message page, or on the fapt side. I cannot get the hydro pump on either, or energy to the servos. Does this work like other yasnac machines where you have to push the on switch twice to get the servos on? I tried it and it does not work. There is only one E stop I can find right on the main crt panel. Any Ideas? |
#11
| Ok, I think it is related to whatever honeywell had as their interlock system. As you can see they added buttons to the crt panel, as well as a bunch of relays and wiring. Can any of you guys decifer what they did? Here are some photos. This is inside the control panel: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#12
| What happens when you rotate the function switch, does it show the functions on the screen just above the soft keys? Not sure what that 'Maintenance Mode' does? Al.
| Need Help!- How to dump (and upload) parameters on O-M | padobranac | Fanuc | 4 | 07-25-2008 02:30 PM |
| fanuc 10tf | morris | Fanuc | 0 | 04-17-2008 10:20 AM |
| Need Help!- Fanuc 10TF PMC Parameters | leturc | Fanuc | 3 | 03-17-2008 10:42 PM |
| Need Help!- proceedure upload heidenhain parameters | bbrreid | Bridgeport and Hardinge Mills | 6 | 02-29-2008 06:42 PM |
| Fanuc 10tf Alarm | L. Sakthivel | Fanuc | 1 | 05-29-2007 10:49 PM |
