Old 09-04-2010, 04:18 PM
tkran is on a distinguished road
rectangular pocket macro
Does anyone have a rectangular pocet macro for a Fanuc Oi control. Basically need the operator to plane to thickness varying sizes of material without offline programming. I am still struggling to learn macro B (Fanuc manuals stink) and really could use the help. Thanks in advance to anyone with advice . Also the planeing tool is 4 inch diameter and the overlap is 3.5 inches per pass .
Old 09-22-2010, 08:51 AM
samu's Avatar
samu is on a distinguished road
Is't it a pocketting cycle or a face milling cycle you want. It looks more like a facemilling. Or maybe you don't want anything cause this post begin to be old.
Old 09-22-2010, 06:03 PM
I would say it is face milling. Basically we are planing rough stock to thickness. I just meant that in respect to the geometry it is rectangular but not really a pocket . The entire surface would be milled to the same thickness. Any help would be appreciated. I have made a looped cycle that calls several subs of various sizes but it takes up alot of space and operators mill alot of air if they dont find a size that is close to the one needed. That is why a macro with variables that can be set by the operator would be so beneficial. Thanks for responding, I had almost lost hope.
Old 09-22-2010, 06:33 PM
CNCRim's Avatar
On go MMSonline.com, I think it was June 2006 issue and there is one article under CNC talk wrote by Mike Lynn. It's axactly what you looking for, I tried and it work like a charm.
Fanuc pocket milling macro tturnbull50 G-Code Programing 4 08-30-2010 02:48 AM
macro for rectangular array of holes sinha_nsit Fanuc 0 04-16-2009 08:51 AM
G34 rectangular box key program help Superiorforge G-Code Programing 6 09-13-2008 10:57 AM
diy vmc from rectangular steel tubing ? andy55 Vertical Mill, Lathe Project Log 7 01-02-2006 03:59 PM
rectangular pocket macro mistux G-Code Programing 0 11-01-2005 11:54 AM
