Old 09-03-2010, 01:08 PM
jay_dizzle is on a distinguished road
EXTRA SPACES WHEN KICKING PROGRAM ONTO COMPACT FLASH?
hello all, another rookie question here. why is it that when i kick a program from my cnc memory (31i fanuc) to my compact flash, the entire program is triple spaced? this makes editing on pc very annoying. not to mention when you re-load it back onto the controller the spaces stay in the program! this makes single blocking your newly edited program a real pain. is there any way to avoid this?
ex; tripple spaced.
X1.0 Y2.0;
X2.0 Y1.0;
X1.0 Y2.0;
Old 09-03-2010, 01:39 PM
dcoupar's Avatar
Check parameter 100 bit 2, (CRF), and 3 (NCR).
100.2 (CRF) Output of the end of block (EOB) in ISO code
= 0: Controlled by setting of 100.3 <---------- set 100.2 to 0
= 1: CR, LF are output.
100.3 (NCR) Output of the end of block (EOB) in ISO code
= 0: LF, CR, CR are output
= 1: Only LF is output. <------------- set 100.3 to 1
So:
If you set 100.2 to 0, you control EOB output with 100.3
If you set 100.2 to 1, EOB will be output as CR, LF.
If 100.2 = 0, then:
If you set 100.3 to 0, EOB will be output as LF, CR, CR (extra blank lines)
If you set 100.3 to 1, EOB will be output as LF.
Old 09-03-2010, 03:11 PM
AHHHH, it's pretty tough teaching yourself how to run a cnc with no formal training..... i think i know what i'm looking for but i'm pretty much lost when it comes to parameters. thanks for the help, i'll give it a try.
Old 09-03-2010, 03:15 PM
so what you are saying is i need to set:
100.2 to 0
-and then-
100.3 to 1
this will solve my extra lines problem? (sorry for being such a newb)
Old 09-03-2010, 03:35 PM
my controller tells me that this parameter is "write protected" WTF, any way around this besides calling the guy who set the machine up?
Old 09-03-2010, 04:09 PM
dcoupar's Avatar
You can unprotect the parameters as follows, but BE CAREFUL! Changing the wrong parameter can spoil your whole day.
In MDI, press OFFSET/SETTING function key, then [SETING] soft key. You should see the SETTING (HANDY) screen. Change PARAMETER WRITE = to 1. You'll get an alarm, but you can ignore it.
Then press SYSTEM function key, then [PARAM] soft key. Type in 100, then press [NO SRH] soft key. Cursor > to the bit you want to change. Key in 1 or 0 and press INPUT.
7 6 5 4 3 2 1 0
_ _ _ _ 1 0 _ _
Now go back to the OFFSET/SETTING screen and change PARAMETER WRITE = to 0, reset the alarm and try outputting the program to the card.
There's also a way to change the EOB output via the ALL IO screen, but I can't find the information on that.
Good luck.
Name:	31i SETTING SCREEN.jpg‎
Old 09-03-2010, 04:29 PM
thanks again, hopefully i'm not being bothersome. you've helped me out on more than one occasion this week i think.
Compact Flash Cards dcoupar Fanuc 6 02-04-2010 12:10 PM
Compact Flash jdgromi Français CNCzone 0 01-30-2010 11:38 AM
Run program from compact flash fomaz Fanuc 13 10-20-2009 02:27 PM
Just IN- Smooth Linear Motion in Compact Spaces with Low-Profile Redi-Rail® Pacific Bearing Product Announcements & Manufacturer News 0 09-22-2009 04:44 PM
Compact Flash to IDE/ATA adapter? DennisCNC Computers and Networking 12 11-04-2007 10:27 PM
