Old 08-30-2010, 08:57 AM
vmcchris's Avatar
vmcchris is on a distinguished road
Angry work offset output
I have a 18M control and I cannot punch fixture(work) offsets. I am able to do tools, macros, and parameters.
What am I missing?
Old 08-30-2010, 09:46 AM
WayneHill's Avatar
WayneHill is on a distinguished road
Some interesting reading on how to output G10 fixture offsets on Fanuc.
http://www.cncci.com/products/option...p/spr05.htm#10
Wayne Hill
www.codemangler.com
Old 08-30-2010, 11:32 AM
stevo1 is on a distinguished road
You may not have the ability to output the work coordinates on that control. I could not find the option to do so in the manual. I have had controls that could not do work coordinates.
If you are in your coordinate screen and there is no key for output or punch then you cannot do so.
Stevo
Old 08-31-2010, 06:42 AM
vmcchris's Avatar
That really sucks!!!
Old 08-31-2010, 07:20 AM
Yes I agree. I never understood why this would be set up that way. Normally it never bothered me because my work coordinates are typically part and fixture features that could easily be set if they are lost. However with some people especially if they have the extended work coordinates then you would for sure want to be able to back them up.
There is a way of getting you values on backup though. When you do a parameter backup it does store the values from G54-G59 in parameters 1221-1226. I don’t have your manual in front of me so I am guessing on the correct parameter numbers. Take a look and see if they are the correct ones.
Stevo
Old 08-31-2010, 07:45 AM
dcoupar's Avatar
vmcchris,
Have you looked at the link WayneHill suggested?
IF your machine has User Macro B option, IF it has the0 G10 option, and IF it's hooked up through the RS232 port, you can output the Work Coorinate Offsets with a macro.
Looks like a workable solution to me.
The other option is as Stevo1 suggests is to output your parameters. Then you could write a Word or Excel macro to extract the correct variables and write them to a formatted text file.
Workable, but much more involved.
Unable to get 'Target Reached' Output to work simpson36 Granite Devices 0 06-27-2010 08:22 AM
setting work offset(G54 etc) dek Machinist Feedback 1 04-06-2010 09:17 PM
Need Help!- work offset Claude Boudreau BobCad-Cam 3 11-22-2009 05:41 PM
Problem- 6M-B 4th & 5th axis work offset changes R-Bob Fanuc 0 10-08-2008 12:33 PM
Rhino output doesn't work... saturnnights SheetCam 9 02-14-2006 11:48 AM
