Old 08-27-2010, 04:52 PM
derek68 is on a distinguished road
g71 type 2
I am trying to use a g71 to rough an internal profile with an undercut. The problem is it wants to do the undercut with 1 cut. I am wondering how I can do this with a g71 type 2? I have never tried it and I am wondering how to get it working.
thanks in advance
Old 08-27-2010, 04:55 PM
sorry it is a fanuc 16t control
Old 08-28-2010, 01:39 AM
dcoupar's Avatar
Post your program here.
Old 08-28-2010, 05:46 AM
sinha_nsit is on a distinguished road
Specify both X and Z in the P-block, for type II operation.
Old 08-28-2010, 12:08 PM
I will post the program when I get back to the shop. what do you mean post the x and z on the p line?
Old 08-28-2010, 12:38 PM
dcoupar's Avatar
G71 P101 Q102 ...
N101 G00 Xnnn.nnnn Znnn.nnnn (P-BLOCK) <--- programming X AND Z in this block specifies Type II roughing cycle.
N102 (Q-BLOCK)
Old 08-28-2010, 04:02 PM
I will try it out on monday and let you know. thanks for the help
Old 08-30-2010, 09:03 AM
here is the program I am still unsure about the p line
g00g28u0w0
n10g54t1111
g96s300m04
g00x2.00z.100
m08
g71u.100r.050
g71p20q30u-.025w.025f.010
n20g00x3.780
g01x0.0f.010
g01x3.52z-.130
z-.658
g03x3.395z-.720r.062
g01x3.1
z-.970
x3.500z-2.00
z-3.5
x2.2z-5.75
z-7
n30
g70p20q30
Old 08-30-2010, 04:41 PM
I figured it out. I had to change a parameter in the controler and everything seems to be working fine.
Old 08-31-2010, 03:17 AM
I doubt.
  #11   Ban this user!
Old 08-31-2010, 08:42 AM
I put the x and z on the p line and i was getting an error no matter what I did. I then was told that I had to change a parameter to be able to use a type 2 roughing cycle on a controler from the mid 90s. I changed the parameter and put the x and z on the same line and now it works
  #12   Ban this user!
Old 09-01-2010, 05:57 AM
g01x0.0f.010
Have you typed this line correctly?
G71/G72 type I vs. type II cycles sinha_nsit Fanuc 4 08-28-2010 05:20 AM
What Type of CNC to get?? FUBAR62172 CNCzone Club House 1 06-26-2009 07:47 PM
G71 type I and type II cycles sinha_nsit Fanuc 5 11-03-2008 05:34 AM
What type of oil to use Grego Shopmaster/Shoptask 2 12-22-2007 01:55 PM
what type of CNC do I need? Goldhunter_2 Mechanical Calculations/Engineering Design 6 06-24-2005 10:57 PM
