Old 08-27-2010, 04:42 AM
tano is on a distinguished road
Takisawa TM20 Fanuc OT control
We buy this machine,we instaled and now we have a problem,spindle dont start.Machine goes to ref.points(x,y,z), tool turret works but only spindle dont start.What are conditions for starting the spindle.I check the chuck, clamp unclamp works fine.In diagnostic parameters when i clamp-unclamp 0-1 change.
I dont have any manual or wiring diagram
Can someone help?
Old 08-27-2010, 10:31 AM
dcoupar's Avatar
There may be one or two proximity switches on the chuck cylinder to verify chuck is closed correctly. Also, there may be a door interlock switch which inhibits spindle rotation with the door open.
Old 08-27-2010, 01:34 PM
GPena is on a distinguished road
Tano:
Have you tried checking the ladder on the screen to see what signal do you need to turn on the spindle ??? I seems that it is only a condition that doesn not allow the spindle to turn, like chuck open/close, door close, lub. oil, etc. this all you can see in the ladder.
Grreg.
Old 08-27-2010, 05:27 PM
GPena
I try to see in ladder but the ladder is not complete.When i open it on the screen ladder apears but without all signals,tags etc.I think that was blocked by parameter 0060 but the value of this bit is 00000110.Any ideas?
Old 08-27-2010, 05:36 PM
dcoupar
On the chuck has two senzors.When i open the chuck one of the senzors lights up and when i close the other senzor lights up.On the door also has two switches but they works fine.Any others ideas?
Old 08-30-2010, 09:10 AM
Try adjusting the bright of the CRT, if you see only lines it is possible that adjusting the monitor you will see the rest of the video.
Greg.
Old 08-30-2010, 12:31 PM
underthetire is on a distinguished road
Did the machine have a barfeeder on it?
Old 08-31-2010, 05:06 AM
zavateandu is on a distinguished road
hi
u tried to rotate with chuck open?
some of these machine has a key to clamp from inside or from outside
u close the chuck but maybe it sets to clamp from outside and is not start.
is just an idea maybe is set to start with chuck open---it means clamp the piece from inside like a ring.
GOOD LUCK!
Old 08-31-2010, 06:50 AM
GPena
Thanks GPena
Now i can see the LADDER but don't know how to use it.How can i find what signals i need to turn the spindle from the LADDER?
Old 08-31-2010, 06:51 AM
zavateandu
I try it ...any other idea?
  #11   Ban this user!
Old 08-31-2010, 07:07 AM
underthetire
Machine now don't have bar feeder but there is connectors for bar feeder.On one of the connectors someone make bypass with two wires.On the other connector cable is cut.When i pull out the connector with cuted cable machine "not ready" appears.
  #12   Ban this user!
Old 08-31-2010, 11:01 AM
Then my guess is someone had a barfeeder on it and tied in to the chuck signal or SDU. This is somewhat common on some barfeeders to keep the chuck from rotating without the barfeeder in normal condition. You will need electrical prints and someone who can read them.
Takisawa TNR-200ys / Fanuc 31i-A control hiihoo Fanuc 4 11-06-2009 07:32 AM
Need Help!- Takisawa TC-1 FANUC 0TC alexfanuc Fanuc 0 10-23-2009 10:23 AM
Need Help!- Takisawa TC-1 with Fanuc OT Nilesh Patel Fanuc 2 10-23-2008 01:13 AM
Need Help!- Takisawa/Fanuc 3T hammerdown Fanuc 0 10-17-2008 09:06 AM
takisawa tc-20 21-t control soft overtravel CVMW General CNC (Mill and Lathe) Control Software (NC) 1 10-10-2007 07:12 PM
