| I am trying to get rs 232 working on 10m controler. I have been looking at other posting for 10 have tryed several cable set ups no matter what I try I get sr821 carrier detect down. The com is hooked into crt bord in control panel, whint through all the settings. I am stomped! This is A machine I got A few weeks ago. Was told rs232 works .Also tryed setting 5000 bit 4 to 1 no chang set back to 0. Last edited by cambridge52; 08-25-2010 at 09:14 AM. |
| Your cable should be as follows: (CNC) (PC) DB25M <-------------> DB9F 1 <--------- shield --- (no connection) 2 <--------------------> 2 3 <--------------------> 3 7 <--------------------> 5 4 & 5 jumpered CNC end only 6, 8 & 20 jumpered CNC end only <---- this should eliminate SR820 and SR821 alarms |
| I don’t know exactly what causes this particular alarm but I had it a few weeks ago. I thought it had something to do with the handshaking line. Anyway it ended up being a blown port on the Base0 board and I had to replace it. I was out of town at the time but worked with the tech over the phone and that resolved the problem. We had a storm and I blew 3 ports on 3 machines. Luckily I had 2 spare ports on the machine already that I switched over to on 2 machines. The 3rd had both ports blown. PM Dan Fritz and see if he can jump in and lend a hand. I know he has been busy because I only got 1 response via email from him and every time I called he was out of the office but it may be worth a try if he has time. Stevo |
| I am not sure. I did some time ago have to use the 20pin Honda connecter on the mother board because the port blew. All I had to do was the pinout and then switch the device being used in the parameters. I am not sure about your machine but this was done on a fanuc 10tf control. Stevo |
#10
| If you jumper the 4-5 & 6-8-20 and still get the alarm, it could be the RS232 IC's which can be easily obtainable & replaced. If you want the 10/11 RS232 manual, PM me an email address. Al.
#11
| Al, How easy is this really to do? I was out of town at the time the Base0 board was replaced but I was talking to the Fanuc tech on the phone when he was here and he could not replace them. He tried and failed so the board had to be replaced. I am just curious as I have never seen, attempted, or heard on how difficult it is. Stevo |
| Alarm 409-servo alarm- z axis torque alm | jessebpm | Hyundai Kia machine | 3 | 06-14-2010 07:45 PM |
| Fanuc 3T - Rs232 - 101 P/S Alarm | Mikadoman | Fanuc | 14 | 05-05-2010 04:07 AM |
| ALARM: SR821 - CD Off (1) | coot | Fanuc | 2 | 07-16-2009 05:47 PM |
| Need Help!- DAEWOO 8 Steady rest pressure alarm, External feed hold alarm | doubleeagle | Daewoo/Doosan | 4 | 06-12-2009 03:15 PM |
| Hurco KM1 RS232 to USB OR RS232 to PCMCIA solution? | modernprecision | Bridgeport and Hardinge Mills | 1 | 09-11-2008 01:15 PM |
