Is it possible?. Ive seen some products such as tool breakage detectors, touchoff probes have all their supporting hardware on one board or a 'box' and then just a few wires have to tie into the factory hardware. I need some way to either read a parameter, or have an M/G/Whatever code have control of an output. the output can be a varying voltage, frequency etc, doesn't matter what it is as long as its scalable with a few hundred value's available. Whatever it is i need to be able to control it from an NC program. If dug though the manuals and poked around in machines after hours but haven't seen anything really obvious. I plan on speaking with the company who resell's machines to us but figured id ask here as well. -Jacob |
| Not sure exactly what you need but you can read the values of parameters in the machine. You can read the values of most of the input/output values that are setup. You can setup a custom M or G code in order to run macro program to check the values of these parameters. What exactly are you trying to do? Stevo |
| Probes, tool breakage, all use either a skip signal or high speed skip signal, not what your looking for. I believe to get what you want, you would have to modify the ladder and parameters to control with an additional axis, and use a 0-10v dac. |
Not quite sure what you are asking. I have a Renshaw probing system on my machine with a fanuc controller. I am using there software to probe a certain piece after I cut it. I then have the results I seek outputed to my macro variables for viewing after the program is complete. Like you, I am also flexible within a few thousandths. I keep my probe regularly calibrated to achieve these results and never had a problem. You do need a basic understanding of Macro porgramming to be able to do this. |
| No macro that I know of can give a variable hard output, IE 0-10vdc signal, or 100 pulses, or whatever. Thats a hardwired function from the control. Inputs from probes are fairly simple, just an on/off basically, the control interprets position and stores them in whatever assigned variables. |
| from your part program, you can create a variety of instructions to/from an external (3rd party) device with the use of macro B interface for the read/write of values, and with M-codes. these instructions is then handled by the pmc program, which needs to be specially written/modified for your required function/device, and output to the selected hardware interface, ie. digital I/O, analog +/- 10Vdc. normally the aim is to select the desired 3rd party device WITH a compatible interface, as most devices have more than one interface type. |
Sorry for the lack of information in my original post, i was on the first pot of coffee of the day, wasn't all there. So it looks as if i need some sort of additional hardware that can just be added to a unit to read memory information, specifically a few predetermined user definable parameters, as prebulit systems do not have outputs tied to parameter values normally. -Jacob |
| Yes in most cases there are unused input/outputs on the machine. I believe depending on the model the input signals for device interface are #1000-#1035 corresponds to UI000-UI031. The output signals are #1100-#1135 corresponds to UO000-UO031. I use the system variables setup by the MTB but never from scratch. This is not my area of expertise. I did a quick search and found a few threads that discuss close to what you are asking about. The links to the threads are below. I hope they help. http://www.cnczone.com/forums/showth...input%2Foutput http://www.cnczone.com/forums/showth...input%2Foutput http://www.cnczone.com/forums/showth...input%2Foutput Stevo |
#10
| Yes, that is what im looking for. As for outputs, they can just be set on/off high/low? Any idea how quickly this can be done? Is there a specific manual from fanuc that covers this? Thank you for the help -Jacob |
#11
| I am not really sure how much is covered in the Fanuc manuals and how much you would need to use the MTB manual. What model Fanuc are you using? I will dig up some manuals if I have them for your model. Stevo |
| Help with Takisawa Mac V2E w/Fanuc Controler Please. | ELECTROMET | CNC Machining Centers | 4 | 12-20-2011 10:27 PM |
| Fanuc CNC controler | zekk_2 | Servo Motors and Drives | 19 | 02-27-2008 01:46 AM |
| Fanuc 31i Controler | TSauls | Fanuc | 1 | 11-14-2007 01:24 PM |
| what fanuc controler do i have? | bcdracing | Fanuc | 3 | 03-21-2007 07:17 PM |
| Wasino with Fanuc OM controler | 9566317 | Fanuc | 11 | 05-26-2005 12:42 AM |
