Old 08-19-2010, 10:13 AM
vmcchris's Avatar
vmcchris is on a distinguished road
Too many digits
I am programming a B axis which is capable of feeding at 5,400 degrees per minute. But I can only program F999. I cannot find a parameter that controls the number of F digits. Can any one help?
Old 08-19-2010, 12:27 PM
cnc2149 is on a distinguished road
What model of FANUC CNC is used?
Old 08-19-2010, 12:29 PM
vmcchris's Avatar
16-M
Old 08-19-2010, 12:31 PM
Try setting parameter 1404.2 (3rd bit from the right) = 1 to extend the commanded feedrate.
Old 08-19-2010, 01:01 PM
vmcchris's Avatar
Thanks. I will try
Old 08-19-2010, 01:07 PM
vmcchris's Avatar
I tried that and still got the 003 Too Many Digits.
So I tried programming the F word without a decimal and it worked.
I set 1404.2 back to 0 and it still works now.
Thank you for your assistance
Old 08-19-2010, 06:12 PM
ou812 is on a distinguished road
I had a similar problem on an 18i-MB. It was fitted with one of the new Direct Drive Rotary 4th axis capable of 250 RPM. I ended up programming in metric to get past the 4 didn't issue. Fanuc said they would look into it, but nothing every came of it.
Hope you find a solution.
OU812
Old 08-19-2010, 06:45 PM
beege's Avatar
beege is on a distinguished road
I once had to use inverse time to feed fast with a rotary. G94? I forget... but figure out how long, say, 5 seconds, program F(1/5) or F.2 It will take 5 secs to get there.
[18i-MB] not allowing custom g-codes over 100 (or 3 digits) gwarble Fanuc 5 03-22-2010 09:13 AM
Alarm 003 to many digits on Hardinge with 18-T HBFixedGear Fanuc 5 12-01-2009 03:26 PM
G-Code output precision always 3 digits? cwm9 SolidCam 11 11-10-2009 01:01 PM
Dialog Digits MikeT BobCad-Cam 2 03-02-2004 08:07 AM
