Good morning, I have a lathe with command fanuc 18i and it's config to work with axis X in radius. That parameters it are necessary to modify to work in diameter, as much I program and offset. Vide |
| With the Series 16/18/20/21 series of CNC controls, you'll need to modify the CMR (Command Multiply Ratio) to work in Diameter programming. Also, there are 2 other parameters to consider, depending on your preferences. 1820: => Present value x 0.5 5004.1 = 0 (diameter offsets) 1006.3 = 1 (diameter rate in CSS) |
| Lathe Diameter or Radius | davidperry3 | Tormach PCNC | 3 | 12-24-2009 11:18 AM |
| Are lathe offset values on radius or diameter? | sinha_nsit | Fanuc | 5 | 11-06-2009 08:46 AM |
| From Radius to Diameter Programming | metx | Fanuc | 7 | 04-10-2008 01:04 PM |
| Lathe Dainichi F35 Fanuc 18TA - change diameter on radius | jutek | Fanuc | 1 | 02-21-2007 03:57 PM |
| VisualTurn diameter v/s radius mode | whiteriver | Visual Mill | 3 | 05-10-2006 11:56 AM |
