We recently changed out the bearings in or Junkford CNC. We are now getting a 511 Alarm. The (x) axis will not go to zero. I have tried to power on using the CTRL + P soft restart. But nothing has changed. (Not sure if I preforming the function correctly.) I have also tried to change the parameters for code 704 and 747 to -999 but the machine still over travels any ideas on how to correct this issue? I'm new to this machine and controls set up......... so I am at a loss. |
| uhhh - as far as I know it's not the ctrl button - the sequence is: with control power off hold down P and CAN at the same time while you turn on the control power - wait to let go until the machine finishes booting up. If you changed a bearing and had the motor removed from the ballscrew on that axis then you have to reset the limits for x axis becasue the absolute encoder still thinks the table is in the same spot as when you took the machine apart but odds are it isn't right? |
| Need Help!- Johnford VMC 750 with Fanuc O-MC lost O9000 program | zpewei | Fanuc | 9 | 02-27-2010 09:02 PM |
| Problem- Lathe JohnFord with Fanuc 18 - need help | longgo | General Metal Working Machines | 4 | 09-16-2009 01:01 PM |
| Need Help!- FANUC 0i for Johnford lathe 2 axis | Arsalan Ahmad | General CNC (Mill and Lathe) Control Software (NC) | 3 | 05-21-2009 03:13 AM |
| Need Help!- Johnford TC-35 Fanuc 18-T | turnertcm | Fanuc | 2 | 02-23-2009 07:42 AM |
| Need Help!- Fanuc OM on Johnford VMC-750 | wicked_won | Fanuc | 1 | 03-28-2008 07:56 AM |
