Im getting somewhere know it appears that someone has been into the parameters of this machine before I bought it. I have got the g43 parameter on the g54 parameter on finally now for the new problem the machine position is reading in mm. absolute distance to go and relative is reading all in inches. does anyone know where the parameter is to swith the machine position to inches. The set up page shows it is set to inches and I gave it a g20 also just to make sure is there anyone out there that can help thanks
__________________ BE NICE TO THE NERDS IN SCHOOL. THEY ONE DAY MAY BE YOUR BOSS Last edited by beekeeper; 08-11-2010 at 09:36 PM. |
| thanks for the info I have been searching the net trying to solve the problems im having I figured out that I was putting an offset in offset oo for g54 when it should have been 01 that fixed that problem now I have discovered that the machine position is reading in metric when the rest of positions are in inches I used o-9999 delete to clear out memory and Im thinking I erased some macro programs that was stored it the 9000 range not sure what to do now.
__________________ BE NICE TO THE NERDS IN SCHOOL. THEY ONE DAY MAY BE YOUR BOSS |
Can I set the machine to metric set it up then switch to inches to run I noticed when you change to metric all inch numbers convert to metric
| From the 6M-Model B Operator's Manual on the "Overall Display": "The unit of the machine coordinate system is the same as that of the machine system." |
| So If I understand right Im going to have to program in metrics to make it run right. If this is the case I am unsure why the even offered the inch to metric parameter on the set up page or allow it to read a g20 without faulting out on the 6m b.
| No, you program in Inches if your Input Unit is set to 1 (either in the Setting Data 01 or by G20 command). The Absolute Position, Relative Position, and Distance to Go displays should all be in Inches. It's only the Machine Position that is displayed in MM, and that has no effect on the program. |
| i set the machine in g21 and set zero in mm in the machine offset page I put the same number in each of 1-6 offsets. I then switched it back to g20 the absolute distance to go and relative was all in inches. The set point was aprox. the center of table. I jog the machine back to close to the reference position gave it an mdi g00 g90 g55 xo yo and the machine took off to where it was going to hit the limits on x and y on the other sides of the table no where nearr where I set the xo yo
#10
| What values did you put in G55 X and Y? I would guess that if you have a 40 x 20 machine, the MM values should be something like X-508 and Y-254 to put the machine in the center of XY. Did you try a move to 0,0 before switching to Inch mode? When you switched to Inch mode, did the offsets convert to inch equivalents, or did the decimal point just move left and the values stay the same? (It's been 25 or 30 years since I've even laid hands on a 6M, so my memory of how they work is rather hazy... sorry.) |
#11
| i gave it metric numbers of x421. y-150. It converted it to inches when I switched to inches. The machine got to the center of table in x and still had 18 inches to go. I stopped the machine when y was about to hit the over travel limit in y- and it still had 6 inches to go. The absolut was reading in inches. I have been talking to a local tech we have alread found a few bad parameters. And fixed them I think someone got into the machine paramaters before I bought it and messed with them. Or I got a low battery. We are currently looking for the original parameters for the machine they wasnt listed in the back panel like some were.
| Converting Fanuc G code to Seimens 840D G code | Jasbinder | Siemens Sinumerik CNC controls | 2 | 02-20-2011 10:02 AM |
| Need Help!- Alarm Code 79 and 86 | RC-CNC | Fanuc | 18 | 02-23-2009 09:37 AM |
| Need Help!- Alarm code 203-6 | meszarosg | Okuma | 3 | 10-11-2008 03:17 PM |
| alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code | sting | Fanuc | 0 | 01-01-2008 09:03 AM |
| fanuc alarm code need help | mike10 | Fanuc | 1 | 10-22-2006 09:26 AM |
