I am getting closer to running got the parameters corrected and I got the use of g43 and g54-59 work offsets. Can some one tell me the correect sequence for setting up the g54 I power on the machine a hitachi 48v reference x0y0z0 I was wondering do I need to g92 it in that position. then go to where I want to zet xoyo in g54 the reference point iss not zero. I do not have an operators manual. Does anyone have a sample copy of g code I can look at. The machine picked up the g43 h1 z1 ok I am hand loading tools so when I got to tool 2 I named it t1 then on next line i had a g43 h2 z1.0 The control did not pick up offset h2 any suggestions sorry for being a pest I have years of experience just not on a fanuc. Thanks
__________________ BE NICE TO THE NERDS IN SCHOOL. THEY ONE DAY MAY BE YOUR BOSS |
| I sent you the G54-59 setup page in the last thread G54 would move X and Z from your External G53 position which is a shift from the X0,Y0 Machine Zero position (not necessarily reference position). T0101 corresponds to tool 1 offset 01 T0112 corresponds to tool 1 offset 12
__________________ *********************************************************** *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~* *********************************************************** *__________If you feel inclined to pay for the support you receive__________* *_______Please give to charity http://www.oxfam.org/en/getinvolved_______* *********************************************************** Last edited by MysticMonkey; 08-10-2010 at 11:26 PM. Reason: oops |
| Hi, What is your machine? Router machine? i am using router machine Fanuc 18-M. I think your machine same as my NC machine. G43 H1; Offset 1, G49 H0 (cancel offset). When open your machine, you need go home machine, after you set G54, G55, G56, G57, G58, G59 any position. G54-G59 Z0 no change. G53 (or position 00 before G54 i need Z0,Y0,Z0) I am not use G92, i use G91 G28 Z0 X0 Y0 Can you post your program and the line offset, G54-G59, G53(00) on your machine? |
| these is my information. O1234; M40 G91 G28 Y0 Z0 M92 (M92 all spindle up) G17 X0 Y0 G90 G10 L2 P0 X0 G90 G49 G40 M95 (M95 all spindle off) G08 P1 T303 M53 M31 G90 G54 M33 S13 G0 X6. Y380. G43 H33 Z20. G1 Z-9. F3000 You see, I use G90 before G54 |
| Parameter setting of Fanuc 18i | alexium2007 | Fanuc | 1 | 04-08-2010 12:37 PM |
| Need Help!- Setting up a Fanuc 6T system | Snowie | Fanuc | 10 | 03-17-2010 01:22 PM |
| Need Help!- Fanuc parameter setting | samiahmed | Fanuc | 1 | 02-18-2010 11:27 PM |
| Fanuc 3T pulse setting | Nandop | Fanuc | 5 | 09-26-2009 05:03 AM |
| Fanuc 11M Control Punch Sequence | carlosdcerna | Fanuc | 1 | 03-18-2009 07:14 AM |
