Old 08-10-2010, 01:53 PM
roofron is on a distinguished road
power supply alarm
need help with what causes the power supply to alarm on 04p-c control
Old 08-10-2010, 03:00 PM
Al_The_Man's Avatar
What is a Fanuc 04p-c control?
Old 08-10-2010, 04:18 PM
cnc2149 is on a distinguished road
The 04PC is an Amada with a 00-PC CNC control. If you are getting the Red LED lit on the Input Unit, then the voltage monitor of the CNC power supply is likely telling the Input Unit to shut down to prevent internal power supply damage. Normally, you can isolate the problem by shedding the various loads. Most of the time, it is not a bad Input Unit or a bad CNC Power Supply.
I usually start by removing the I/O C7 board from the master board. Most of the time, an external machine-side short circuit is pulling down the 24E supply so this will disconnect the machine side from the CNC side. If it comes up w/o the Red LED lit, re-install the I/O C7 board with none of the 5 Honda plugs connected. If it fails to come up, you have a bad I/O C7 board. If it comes up, power down, connect 1 of the Honda cables and try powering up again. Keep doing this until the machine will not come up to identify the shorted cable. Once you find the shorted cable, it's a matter of chasing the short on the machine side (e.g. bad cable, relay, switch, etc).
There can be more to it than I wish to explain here in the first reply (e.g. you can have an external I/O board hanging off of the PMC-M ROM board) but following the steps above is a good place to begin.
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
New Power Supply for my X2 ibuildstuff4u Benchtop Machines 21 08-24-2009 05:49 AM
Need Help!- Which Power Supply? jaru-eri DIY-CNC Router Table Machines 1 04-07-2009 11:15 AM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
