Old 08-09-2010, 12:25 PM
lovell110 is on a distinguished road
Unhappy Bridgeport Romi with Fanuc OT
I need some help! I have a Bridgeport Romi with a Fanuc OT control. I am tryin to run a bar pull job. The machine had a barfeeder at one time. I cant seem to get the machine to oopen and close the chuck via the G codes (M24 open M25 closed). When I try either code in the MDI screen the chuck will actuate however the machie does not get a signal for completion. I do not want to use the sensors on the actuator. How do i go about finding what parameters control this? Im not very good at ladder diagrams so those of you who guide me down that path I ask for your paitence in advance.
John
Old 08-09-2010, 02:47 PM
underthetire is on a distinguished road
Why the hell would you not use the sensors on the actuator?
Old 08-09-2010, 03:01 PM
Its simple. One of them is bad and Im against the wall for a delivery. I know its not the right way to do things however Im in a pinch Im hand pulling right now. Thats no fun either!
Old 08-09-2010, 03:09 PM
That makes more sense then I don't have a ladder for your machine, but I can tell you grainger carries prox switches in stock if you have one close to you. I usually had my customers get there replacements from there same day.
Old 08-09-2010, 03:25 PM
I can see the ladder! I can see it change when i activate the clamp/unclamp button on the chuck. I just have no idea what it means! Ive never had to fool with this side of the CNC control.
Old 08-09-2010, 08:49 PM
Unhappy
OK progress has been made. Both chuck actuator sensors are working. When I say working I mean the proximity light on the sensor goes out when the actuator clears the range of the sensor. When I close the chuck in MDI it works fine. The machine gets the signal the chuck is closed. When I do this to open the chuck the chuck will open however the machine does not get the signal that the chuck is open. Any ideas?
Old 08-10-2010, 09:07 AM
Can someone tell me where in the diagnostic parameters to look to make sure my chuck actuator sensors are working? I want to make sure they are working before I go deeper.
Romi-Bridgeport PowerPath 15 users? RedGTZ Bridgeport and Hardinge Mills 41 10-04-2011 11:32 PM
Bridgeport/ROMI Engine lathe smittys800 Bridgeport and Hardinge Mills 19 04-14-2009 09:02 AM
Need Help!- Bridgeport Romi Lathe zdude Bridgeport and Hardinge Mills 6 09-23-2008 07:38 AM
Bridgeport Romi Password md63825 Bridgeport and Hardinge Mills 9 08-16-2007 05:53 PM
Need HELP on Bridgeport EZ-Path ROMI Lathe Michael Esch Machine Problems, Solutions , Wireless DNC, serial port 6 04-09-2007 10:38 PM
