hi i have a NCT TMC 40V machine center with FANUC 15 MA i lost parameters, i extracted manual from tape and i put in also by hand but when i want to use rigid tapping cycle i get an alarm: ex 24: machine is abnormal condition on rigid mode and is canceled by M30 OR M40. if someone knows what parameters should i set cause i am sure these parameters where not on the tape and i do not know . Thanks fro your help HAVE A GOOD DAY! |
| HI M8 i know this is already activated is all about that the machine get in position but the spindle do not start to rotate just wait some seconds than i get the alarm. so the cycle is activated but is just a no corespondence for the rigid tapping cycle between z axes and spindle from parameters. |
| I had problems setting the 5600, 5700 and 5800 series parameters on my 15-MA. My Parameter #9122 option bit 4 is set so I don't know if that will help either. I had to follow the parameter setting of machines like mine for this option. My problem with it, is that the Spindle servo connected through the amplifier A06B-6059-H002 does not accel/decel like it should, although it does work and it is fairly smooth.. Thanks for the PDF, FrankCNC. Greg |
These are the parameter settings on our 15MA Daewoo ACE-H100 #1837 X16000 Y16000 Z32767 B1600 #5604 00000000 #5605 00000010 #5610 0 #5691 1101 #5692 1101 #5693 1101 #5694 0 #5695 0 #5696 0 #5697 0 #5698 0 #5703 0 #5704 0 #5751 4000 #5752 10 #5753 2512 #5754 32767 #5755 20 #5756 0 #5757 2000 #5801 0 #5802 0 #5803 0 #9122 00010010 Hope this helps. |
| I'll check this against my setup. My parameters were hand entered because the machine is a custom built machine. My last rigid tapping experience with the 15-MA was doing some 1/4-20, 5/16-18 and 3/8-16 taps into some 1018 steel, hich was about 1/2" (0.500" or abt. 12 or 13mm for you metric folks. They were Reiff & Nestor HSS H3 class taps. I don't remember the speed or feedrate.. but I tried to keep my setup rigid as possible. These were not blind tapped threads. I tried my Hanson Whitney taps but one broke before on the spindle reverse. I did remember though that the fit seemed about 75% so it was pretty good when i checked it with my gage. They werent really even critical but I wanted to be sure so I checked them anyhow both with the actual fasteners used and the gage. Now that I think about it, the spindle speed was about 300-500RPM but still cant recall the feed. Greg |
#11
| This works on my 15MA, if using G94 the feed rate F is in mm/min, if using G95 the feed rate F is tap pitch, no need to code in M3 (M4 for G84.3 Left hand tap) as rigid tap cycle starts the spindle itself. O5001 G17 G21 G40 G54 G64 G80 G90 G94 (feed/min) (T57 SPIRAL TAP 5/8-11 UNC) N10 G90 G10 L1 P57 R288.4 G63 G90 G0 X257. Y-75. S204 G43 Z700. H57 Z677. G98 G84.2 Z633. R677. F471 (F = mm/min) G80 G64 G0 Z700. M9 G91 G28 Z0. M5 M1 M30 % O5001 G17 G21 G40 G54 G64 G80 G90 G95 (feed/rev) (T57 SPIRAL TAP 5/8-11 UNC) N10 G90 G10 L1 P57 R288.4 G63 G90 G0 X257. Y-75. S204 G43 Z700. H57 Z677. G98 G84.2 Z633. R677. F2.3091 (F = tap pitch) G80 G64 G0 Z700. M9 G91 G28 Z0. M5 M1 M30 % |
| Fanuc PML-L&M Problem | taspunsaen | Want To Buy...Need help! | 3 | 01-16-2012 08:32 AM |
| Need Help!- Problem with fanuc 01 | dopamine | Fanuc | 2 | 04-10-2010 10:31 PM |
| FANUC-OM ATC Problem | Stebedeff | Fanuc | 1 | 07-27-2007 10:18 AM |
| Fanuc OT problem | Skybrake | Fanuc | 16 | 02-09-2007 12:04 AM |
| Fanuc 6M Problem | Mimas | Fanuc | 3 | 12-16-2006 06:03 PM |
