Old 07-31-2010, 03:22 PM
Terabithia is on a distinguished road
Hardinge Indexer Macro
Currently the company I work with is programming a series of DPRINT commands in the main program to index a Hardinge 5C indexer on the machine, via the RS232 interface. I want to change this so we can use a macro to do the work, and call the macro via an m-code. The machine is setup to use M250 for an indexer subprogram already.
Code I have tried is as follows, called by M250 A? from the main program.
O9250 (HARDINGE INDEXER MACRO)
POPEN
G4 X.1
DPRNT[BS000.000]
G4 X.1
DPRNT[BF250.000]
G4 X.1
DPRNT[BB]
G4 X.1
DPRNT[BS#1[33]]
DPRNT[BB]
G4 X2.0
PCLOS
M99
The indexer errors out with a format error on the "DPRNT[BS#1[33]]" line.
I am told this indexer will only work in incremental, is that true? My goal would be to pass an absolute angle to the indexer via the m-code and not have to track the current index position.
Any help is much appreciated.
Old 08-01-2010, 05:07 PM
norbert.barnard is on a distinguished road
have you tried M250 A3 (A = tool number you want)
Old 08-06-2010, 09:35 AM
gwarble is on a distinguished road
i think you need spaces:
DPRNT[BS #1 [33]]
to print an actual space you need to use asterisk * but a space in the code seperates text from variables i think
Need Help!- Adding Hardinge 5c indexer to Excel 10T24 interface sneezeguard General Metal Working Machines 0 11-19-2009 12:17 PM
Drill Macro by Hardinge Al_The_Man General CNC (Mill and Lathe) Control Software (NC) 1 05-03-2008 08:36 AM
Hardinge 5C Rotary indexer on FADAL'S srmodelmaker Fadal 5 01-21-2008 08:29 AM
Hardinge 5C Rotoary indexer srmodelmaker Bridgeport and Hardinge Mills 0 01-09-2008 10:40 AM
hardinge / haas indexer parameter 30 ? jim007 Bridgeport and Hardinge Mills 0 02-19-2007 03:13 PM
