Old 07-30-2010, 12:46 AM
dansteinmetz is on a distinguished road
Fanuc 6T wont start up
I power the machine on, then hit the on button for the control. I can hear a contactor snap in, then instantly pop out. CRT doen not light up, nothing. a red light will briefly light on the power supply, but goes out when the contactor shuts off. Power supply maybe? Is there a way to test these power supplies?
Dan
Old 07-30-2010, 02:14 AM
Boots is on a distinguished road
Was the machine running fine before ? What changed if anything? Are the backup batteries dead? Have you checked to see if one of the legs is dead on the 3 phase power input. Typically a blown fuse will cause this.
We all live in Tents! Some live in content others live in discontent.
Old 07-30-2010, 02:38 PM
bmngator is on a distinguished road
Watch Dog alarm will also cause this. Are there any LED'S lit on your master pcb?
Old 07-31-2010, 12:42 AM
zavateandu is on a distinguished road
CHECK YOUR 24 V POWER SUPLY
Old 07-31-2010, 09:08 AM
GERARDO is on a distinguished road
FANUC TURN ON MISSED
I HAVE A FANUC 6M, THIS CONTROL HAS A GLASS FUSE OF 5 AMP, IN THE BACK CONTROL.
THIS PROTECTION IS FOR CONTROL VOLTAGE (100 VOLTS AC @), WITH A SHORT CIRCUIT THIS PROTECTION IS DAMAGED AND THE CONTROL TURN OFF.
I SEND YOU ONE PICTURE.
Old 07-31-2010, 11:22 AM
cncdiag is on a distinguished road
Remove wires from the righthand side of power supply (make sure you mark them first) Remove white connector. Turn on control and check voltages on power supply, if you have no output voltages, check input unit to see if you have a red led on, if you do, you have a bad power supply. If you do have the output voltages, you have a short on the machine, connect one wire at a time until you find what wire is shorted
Old 07-31-2010, 09:58 PM
Snowie's Avatar
Snowie is on a distinguished road
My t6 did did this. I reordered my 3 Phase connections until my chip conveyor was running the right direction. Replaced the fuse and presto all running
Snow
cd-100 wont start urbanimports02 Novakon Systems 1 04-19-2010 05:43 PM
Need Help!- spindle wont start BP series 2 spock Bridgeport and Hardinge Mills 0 10-16-2009 11:28 AM
Now Madcam wont start cxevalo MadCAM 1 12-01-2008 12:20 PM
Boss 5 series 1 BP, spindle wont start signweld Bridgeport and Hardinge Mills 3 11-16-2006 06:21 PM
Everything Just Stopped and Wont Start Eng2Aviator Xylotex 4 06-28-2006 06:12 PM
