this alarm is showing that the value set in parameter 1828 or 1829 has been exceeded.
Normally this is caused by the axis not moving at all, which could be caused by a mechanical problem or an electrical one such as blown fuse in axis drive, wiring issue etc.
When you reply, please indicate exactly which model 21 you have (a,b,c,ia,ib).
LinkBack URL
About LinkBacks
