Old 07-25-2010, 12:43 PM
gnmachine is on a distinguished road
21iT: Using 2 offsets for 1 tool:Machine stops for tool change
I have a 1999 Romi M17 with a 21iT control. I use a Dorian wedge-style toolpost. I am using a tool which one side is used to turn the OD, then the other side turns the ID. The problem I'm having is the machine stops and waits for a tool change when I would like it to just automatically change the offsets and continue machining. I'll give an example of the spot in the program:
T1111 (OD);
M3;
M8;
G42 GO X1.30 Z.05;
G70 P1 Q2;
G40 G30 UO WO;
T1212 (ID);
M3;
M8;
G41 G0 X1.00 Z.05;
G1 ZO.O F.002;
X.96;
X.942 Z-.009;
Z-.250;
G40 X.880;
G0 Z.5;
G30 U0 W0;
M1;
M30;
Usually, I would add a M1 after the G30 U0 W0, and this stops the machine.
I just always thought that was what it did.
Any ideas on what I'm doing wrong? Do I need to adjust a parameter?
I would really like to have the machine continue on it's own without having to push the tool change button.
Old 07-25-2010, 02:24 PM
dcoupar's Avatar
Usually when you use two offsets for one tool, only the last 2 digits change (so it doesn't index). Try
T1111 (OD)
T1112 (ID)
Old 07-25-2010, 02:29 PM
dcoupar, I am pretty sure that I tried that on Friday. I'll make sure that I try it tomorrow and see where it goes.
Old 07-26-2010, 07:42 AM
sinha_nsit is on a distinguished road
Usually the last (rightmost) two digits of a T-word specify the geometry as well as wear offset numbers (which are row numbers of the respective offset tables), and the remaining digits (one or two) at the left designate the tool number on a lathe. The numbering scheme for geometry offset, however, depends on a parameter setting. Though the leftmost two digits always designate the tool number, a different parameter setting will cause these digits to be interpreted as geometry offset number also. The rightmost two digits are always wear offset numbers.
Old 02-01-2011, 08:10 AM
kattoju is on a distinguished road
Please share the information
May I know if you have got the solution. I am interested in it. Please do let us know how did you address this problem.
Thank you,
Kattoju
T1111 (OD);
M3;
M8;
G42 GO X1.30 Z.05;
G70 P1 Q2;
G40 G30 UO WO;
T1212 (ID);
M3;
M8;
G41 G0 X1.00 Z.05;
G1 ZO.O F.002;
X.96;
X.942 Z-.009;
Z-.250;
G40 X.880;
G0 Z.5;
G30 U0 W0;
M1;
M30;
Machine stops at end of tool path Cellar Dweller Mastercam 5 09-29-2009 05:14 AM
Machine skipped a tool change?? panaceabea Haas Mills 21 04-26-2009 05:55 PM
setting the tool data and the tool offsets Michael82 Mazak, Mitsubishi, Mazatrol 6 01-23-2009 01:50 AM
Machine hang during tool change javajesus Sharp CNC 44 01-19-2008 10:27 PM
variable to change tool offsets in auto cycle dalvinder Machine Problems, Solutions , Wireless DNC, serial port 0 09-04-2007 03:45 PM
