Old 07-23-2010, 06:05 PM
Ozemale6t9 is on a distinguished road
Fanuc Power Mate
I am having problems getting certain functions on a machine going, and I think it may be related to the Power Mate unit. This unit is A02B-0168-B011, and when the machine is fully powered up, it has a red L.E.D. labelled S1 flashing. I do not have any info for this unit, so I don't know what this L.E.D. indicates.
Anyone had experience with these units, or maybe a maintenance manual in PDF format you can send me? Any help would be greatly appreciated.
regards, Oz
Old 07-27-2010, 03:14 PM
RRL RRL is offline
RRL is on a distinguished road
S1 LED
The S1 LED is just an indication the the unit is in an alarm state.
You will need to connect an MDI/DPL unit to the PowerMate to see what the actual alarm is.
RRL
Old 07-27-2010, 04:07 PM
underthetire is on a distinguished road
Handy required unless you have a later control then you can see it in the PMM screen.
Old 07-27-2010, 04:23 PM
cnc2149 is on a distinguished road
The PMM feature is the Power Motion Manager which is an interface to monitor and configure the Beta I/O Link servo drive units. These amplifers connect to the CNC through the I/O Link bus (JD1A/JD1B) connections and don't add to the CNC axis count. The PMM has pages for Parameters, Diagnostics, and Messages that are essentially separate from the CNC controlled servos.
The A02B-0168-Bxxx is actually a Power Mate E. This is a combination of a single axis 'CNC' controller and servo amplifier that has it's own PMC Ladder, part program area, parameters, diagnostics, etc. The only HMI interface offered is the MDI/DPL unit to be able to see the alarms or set parameters, etc. In some applications, it communicates with a master CNC through the I/O Link (when used as a tool changer axis, etc), but the I/O Link is only used to exchange data and not always to program each command statement.
Need Help!- RS232C Communication to Power Mate bitwise Fanuc 0 09-05-2008 10:20 AM
Problem- Power-Mate Model D iNUC Fanuc 1 04-19-2008 10:20 AM
Power Mate D Bluesman Fanuc 1 05-11-2007 06:53 PM
Fanuc Power Mate Bluesman Fanuc 1 01-02-2007 02:30 PM
Fanuc Power mate D M.RISHIKESH Fanuc 0 12-04-2006 10:28 AM
