| Without prints, hard to tell, but I have put in many barfeeders and most of the single tube ones use pretty much the same signals. You usually have end of bar signal, barfeed unlatched signal ( for loading new bars ), emergency stop, some have barfeed on signals as well. Single tube units can be put on pretty much any lathe. |
| Bar alarm= barfeeder in place and locked down Bar OK= barfeed running EOB=end of bar You will need to tie in the the factory Estop so the barfeed Estop shuts everything down. 2 wires, no big deal. If you don't and someone hits it and it doesn't shut the machine down you could end up with a huge lawsuit. |
| you have to be weary buying a barfeeder that is not designed for the lathe as sometmes the ladder in the lathe will not have the correct logic for the barfeeder.
__________________ *********************************************************** *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~* *********************************************************** *__________If you feel inclined to pay for the support you receive__________* *_______Please give to charity http://www.oxfam.org/en/getinvolved_______* *********************************************************** |
| Is this the best option? | Eusk | Stepper Motors and Drives | 1 | 03-10-2010 05:27 PM |
| Okuma mill feed rate jumps to rapid feed | easyguy97 | Okuma | 6 | 12-20-2009 04:14 AM |
| Need Help!- 3D OPTION | stevieboy | HURCO | 6 | 12-11-2009 10:42 PM |
| scanner option | woodman08 | Mach Mill | 0 | 10-30-2008 11:44 PM |
| TM-1/TM1-P Spindle Option | HelicopterJohn | Haas Mills | 1 | 10-31-2007 10:35 PM |
