Old 07-07-2010, 10:01 AM
Fire_Fly666 is on a distinguished road
fanuc g73 ot controls
I really need to find out how to "properly" use a g73 on fanuc controls for a lathe. When I was attemping this last night I was dumbfounded to find out that there was do "D" on the controls.......how odd, any way apon closer inspection I found out That to use this profile repeat code it actually uses 2 g73 blocks. Can anyone please explain to me how to use this code and what EXACTLY all the letters do in it, what they are for, and how to do any calculations to use any of them, thank you for your time.
Last edited by Fire_Fly666; 07-07-2010 at 10:03 AM. Reason: spelling and add the machine in.
Old 07-10-2010, 07:04 AM
stevo1 is on a distinguished road
Canned cycles on lathes are not my strong suite but I use them enough to give you some info.
Lets say you want to turn a OD flange of 8.5” 1.5” deep and the OD is at 9.5” you would write your code something like this.
G0X9.5Z1.
Z.1
G73P10Q20U()W()D()
N10G0X8.5
G1Z-1.5F()
N20X9.5
G0X12.
Z3.
M30
The P10 and Q20 are the blocks that the canned cycle will run N10 to N20. The U() is the finish stock you want to leave on the diameter (X). The W is the finish stock you want to leave on the face or Z. The D() is your pick size. If you don’t want to leave finish stock then they will be U0W0.
Hope this helps. If anyone has a better example/info please share.
Stevo
Old 07-16-2010, 03:52 AM
sinha_nsit is on a distinguished road
If you need information about 2-block G73 code, pl let me know.
Tags
g73
alarm 86 fanuc controls machineman66 Daewoo/Doosan 2 06-12-2010 06:32 AM
fanuc controls at fadal link 6105Moss Fanuc 0 11-03-2008 10:48 PM
fanuc controls gabedrummin Fanuc 3 10-22-2008 08:33 PM
flash cards for fanuc controls rags Fanuc 9 10-09-2008 09:21 AM
Fanuc 11M controls reference zero liston336 Fanuc 2 04-06-2007 05:14 PM
