Old 07-07-2010, 01:48 AM
Rzadziu is on a distinguished road
Groove on OD
Hello everyone
This is my first post on this forum and i have to start with small problem.
Im trying to do a groove on OD of the pipe. The groove is shaped like a rectangle with roundet corners and unfortulately I don't know hove to program it.
I tried to use Manual Guide but then simulation is stoped before corners.
I working on 3 axis lathe with FANUC Oi-TC.
This is the program for something similar and also it's stop befor radius
( FL-PLAN-NUTEN )
G21
M98P9966
T563(3MM)
G98
M05
M50
G00C0
G97S4000M23
G18
G1051D3.L1.5F100.V100.E80.W1.B1.5C2.Z3.
G1600T4.H-9.1V0.I-9.1J0.B46.L-4.D3.
G1601H-9.1V19.085544K3.D30.L0.M0.
G1605H-14.1V24.085544R5.I-14.1J19.085544K3.
G1601H-54.1V24.085544K5.C-54.1L0.M0.
G1601H-54.1V-24.085544K7.D-30.L0.M0.
G1601H-9.1V-24.085544K1.C-9.1L0.M0.
G1601H-9.1V0.K3.D0.L0.M0.
G1606
M25
M51
M37
G99
M98P9966
M01
M99
I was attached a drawing where the groove is marked in red color.
If anyone knows how to make the groove or can make understandable sample please contact me
Best regards
Marcin
Old 07-07-2010, 06:34 PM
CNCRim's Avatar
Your code look quite diffrence than from what I normal know, but you said Fanuc so I have some thing that I had done. You can try program few difference way, first try G107(cylinder interpolation), if doesn't work then try G112(coordinate interplation), G112 will require little twist but quite easy, CAM recommended for this.
N1
(C-ENDMILL)
G0M5
M8
M69
G98G19M45
G28H0
G0T1111
G0Y0
G97S200M13
S511
G0Z.1
X200.4
G1G19W0H0
G107C80.
G1C0Z-20.F40.
X160.01F1.53
C70.646F3.06
G2C86.373Z-29.5597R30.
G1C93.627Z-40.4403
G3C109.354Z-50.R30.
G1C250.646
G3C266.373Z-40.4403R30.
G1C273.627Z-29.5597
G2C289.354Z-20.R30.
G1C360.
X200.4
G107C0
G0X200.4
Z.1
M01
Old 07-07-2010, 11:55 PM
Hi
Thanks for your reply but this program does not work.
The program stops on M69.
Old 07-08-2010, 03:51 AM
dcoupar's Avatar
Originally Posted by Rzadziu View Post
Hi
Do you get an alarm (such as Invalid G Code) when you try to run CNCRim's program, or does it just stop? It may be your machine doesn't have the Cylindrical Interpolation option turned on.
I don't believe his suggestion to use G112 will help you. That's for Polar Coordinate Interpolation, used for milling in the face of the part.
My ManualGuide-i doesn't want to run, so I can't help you with your program, but if you need to cut a part I can generate a "longhand" program to get you going.
Old 07-08-2010, 04:02 AM
Machine just stop without any errors.
Can you tell me what parameter I need to check for turning on Cylindrical Interpolation.
Yes please if can generate program I will be grateful.
Regards
Marcin
Old 07-08-2010, 09:50 AM
dcoupar's Avatar
I've attached a .txt file that can be called as a sub after you get the tool turning and positioned over the start point. I'm not sure about feedrates, so be careful.
As far as the Cylindrical Interpolation option, I don't have that information.
Old 07-08-2010, 06:50 PM
CNCRim's Avatar
So, I am. I don't have that info. The example I gave you is worked and tested program(it was for Mori and Funuc).
Old 07-09-2010, 12:28 AM
viorel26's Avatar
viorel26 is on a distinguished road
Hi
Don't use M69
CNCRim what is M69 ??
Old 07-09-2010, 12:50 AM
Hi
"decoupar" I tested this program and it works great. In fact, I had to change the feed because I was a little too small now I have a F200. But I have to You one more request, if you can generate the same program only with the start point in Z-4.5
Marcin
Old 07-09-2010, 12:54 AM
Maybe my machine don't have some function.
  #11   Ban this user!
Old 07-09-2010, 02:40 AM
dcoupar's Avatar
Here you go. Start point at Z-4.5 and feedrate at F200.
  #12   Ban this user!
Old 07-09-2010, 10:55 AM
CNCRim's Avatar
Originally Posted by viorel26 View Post
Don't use M69
m69=brake off
V- Groove Bearings cianmull Want To Buy...Need help! 0 03-03-2010 12:05 PM
Need Help!- G75 groove cycle oregoncnc Mori lathes 3 02-18-2009 11:24 PM
Newbie- Groove on O.D dpark1 Solidworks 1 07-31-2008 05:31 PM
O.D. Groove Stickmchn G-Code Programing 10 12-08-2007 04:29 PM
V-Groove Bearings widgitmaster DIY-CNC Router Table Machines 24 02-27-2007 02:14 PM
