Old 06-29-2010, 09:10 AM
humak16 is on a distinguished road
How to increase memory of Fanuc 0-MC control
I have a Cincinnati CNC Machining Center Sabre 500 with Fanuc 0-MC control. Initially it's memory was about 16Kb. I have enhanced it's memory to 32Kb through parameters. Now when I try to further increase it's memory to 64 or 128Kb through parameters, the control does increase the memory but it shows 128 Kb under the heading 'Used Memory'. It shows Free memory as zero. Memory board of machine is A16B-1212-2110/11c. 4 x SRAMS are mounted on the board each with 256Kbit capacity. Can I increase the capacity by adding more SRAMS to the board? Please suggest solution.My e-mail address is < humak16@comsats.net.pk >
Old 06-29-2010, 09:13 AM
Al_The_Man's Avatar
Contact http://www.tulipmemory.com/
Old 06-29-2010, 10:10 AM
stevo1 is on a distinguished road
IIRC this typically means that you have increased the memory past the amount of hardware to support it.
Stevo
Fanuc Pro 3 Control 16i Memory Card Error bassboarder85 Fanuc 12 11-12-2010 03:24 PM
Fanuc 18i, how to increase storage memory teal854t Fanuc 2 07-31-2009 04:55 PM
Program # increase on fanuc 16-M control beam Machinist Feedback 2 11-20-2008 12:53 PM
Increase memory size on R2E3? cut more Bridgeport and Hardinge Mills 4 05-31-2008 08:08 AM
Increase M-V5B Memory ar15 Mazak, Mitsubishi, Mazatrol 0 05-28-2007 08:16 AM
