Old 06-28-2010, 06:16 PM
MadMax is on a distinguished road
Fanuc 18T ladder help please - anyone know the symbol for Cyl' start?
I just finished repairing my live tool drive on a Hardinge Conquest 42T with 18T controller. For some reason my "cycle start" button has gotten hinky. It takes several presses for my machine to register the press in MDI mode or automatic.
I've already tested the switch to see if it has a bad contact as well as the "feed hold" switch to see if was stuck on, but both switches are behaving properly. Strangely if I open the door the control consistently registers the switch press (door warning immediately comes up) so I no longer suspect a bad switch. It seems as though the control is registering the switch press, but some other condition is not being met on a consistent basis.
I've checked the live tool motor connections and they look good. All covers are on (no cover switches open) and all liquid levels and pressures are good. I'm not getting any error messages so I'm pretty baffled at the moment.
Further clues: manual jog is not working. I can open and close the collet in the main spindle, but I cannot jog it in any direction. All feed and spindle overrides are not at zero.
I'd like to look at any references to "cycle start" in the ladder, but I can't find it in the thousand or so pages. Does anyone know the symbol for this switch so I can search for it? I've found "feed hold" (FEHD.P) but figure out the symbol for cycle start because there aren't many references to it in the ladder.
Thanks for your help!
Old 06-29-2010, 12:28 AM
dinesh is on a distinguished road
check for G 7.2 bit(pmc to cnc signal for cycle start) And G8.0(Interlock signal) for the axis movement in the PMC ladder logic,
gudluk
Old 06-29-2010, 09:48 AM
underthetire is on a distinguished road
The fact you cant jog the spindle would lean towards the clamp ok signal. Either prox switches on the actuator or a pressure switch. (seen both on Hardinge)
Old 06-29-2010, 05:02 PM
FrankCNC is on a distinguished road
Re: Fanuc 18T ladder
On our 15MA cycle start in the ladder is ST.P
Old 06-29-2010, 05:58 PM
Thanks guys!
I managed to find the cycle start reference. It's CYCS.P on the 18T. I traced it and seem to be stuck on an input "6" which looks to be an amalgamation of checks which feed into a "STOKC" value (start ok C?). Backtracing 6 shows a pile of stuff which shows an "on" value except for a pair of parallel conditions:
-SSLKPN (non inverse)
-SSOPT (inverse)
Both are in "off" condition so I can't make 6 output an "on" to satisfy STOKC which is in series with a string to satisfy STOK and a final condition to satisfy "CYCLE START OK".
Any idea what SSLKPN AND SSOPT refer to?
Old 06-29-2010, 10:51 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
On the ladder screen you can switch between SYMBOL and ADDRESS
give us the addresses
If they are Rxxxx.x type they are MTB specific
IF they are F,G type they are fanuc standard which we should be able to look up
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 06-30-2010, 09:30 AM
Thanks MM I didn't realize that there was an address behind the symbols.
SSLKPN: X5.6
SSOFT: K5.4 (some keeprelay I don't know much about)
Old 06-30-2010, 10:52 AM
Fixed! I had a Fanuc guy by today to look at the ladder. He pointed out that X5.6 referred to a physical switch and K5.4 was a keep relay value. They eventually point to a sub spindle lock pin and a bypass keep relay bit.
Some months ago I tried to remove a seized collet in my subspindle. The lock pin broke so I removed it. It looks like the solenoid core has drifted down off the unlock confirmation switch so one of the "start ok" conditions isn't met "STOKC". Toggling the K5.6 bit bypassed the switch and fixed the problem. Now I'm diving into the subspindle to fix the switch issue.
Fanuc OT-C Ladder Paavan Rastogi Machine Problems, Solutions , Wireless DNC, serial port 6 06-27-2011 06:33 PM
Fanuc Ladder III PMC->PC fomaz Fanuc 2 04-13-2010 07:15 AM
Help for PMC ladder for Fanuc O-M giorgis Fanuc 2 04-23-2009 12:57 AM
ladder fanuc om-a rathi_vk Machine Problems, Solutions , Wireless DNC, serial port 1 01-11-2009 01:34 PM
New Machine Build- FANUC LADDER CHAD LAWSON Fanuc 7 12-08-2008 12:47 PM
