Results 1 to 6 of 6
Thread: Fanuc OMB Spin Not Safe Error
    Aug 2007
    Makino FNC106 - Fanuc OMB Control. Tool out of order & had a hard crash. Machine runs fine if spindle is not under a load. Will dry run program @ max RPM for hours, but when you put spindle load, returns error No. 2028 Spin Not Safe & machine stops. The spindle sounds fine & runs up to RPM fine. Spindle is not heating up. Machine is not running for a long duration to fault out, totally random.
    Feb 2009
    Is that the little Knee type Makino ?
    Aug 2007
    No, fairly good size 24 x 46" CAT50 spindle. Ran ok all day. Intermittent problem at this point. Mike
    May 2009
    any fanuc alarms?
    Aug 2007
    No 2028 Spin Not Safe on console
    May 2009
    you have to cal makino for that.. its their alarm
    1. Need to Open a safe
      By jimalb in forum Hobby Discussion
      Last Post: 06-04-2009, 10:30 AM
    2. Is Machinable wax safe ?
      By laszlozoltan in forum Safety Zone
      Last Post: 06-01-2008, 04:26 PM
    3. Is this safe?
      By foam27 in forum General Electronics Discussion
      Last Post: 06-15-2006, 07:08 PM
    4. Is this safe?
      By Hack in forum DIY CNC Router Table Machines
      Last Post: 07-27-2005, 08:00 PM
    5. Is it safe?
      By kong in forum Gecko Drives
      Last Post: 11-24-2003, 10:56 AM
